Motu M2 periodic buzzing noise
Hey,
so I got a new Motu M2 Interface about a month ago. Since then there are periodic buzzing sounds coming from the Headphone Amps at "random" times. Sometimes it runs 3 hours without a Problem and sometimes the buzzing happens twice in 5 minutes. Turning the Interface off and on again "fixes" the buzzing temporarily.
The output meter isn't showing anything of it and I already sent the first unit back and received a new one, with the same result. So at this point I am suspecting some Problem with my PC. I am not unfamiliar with how to setup a Computer properly for Audio Production, so I already worked through "all" the common steps. Got a suspicion, that it might has to do with my PSU, which is an older unit... but that's really just a guess into the dark.
I'm working on Windows 10 with fairly new Hardware (besides the PSU) and I'm starting to run out of ideas. I also recorded the buzzing ( https://voca.ro/1llmN9gokfKO ). Sorry for the noisy Background...
I would really appreciate any idea or advice on how to figure this out.
Re: Motu M2 periodic buzzing noise
Is there a PC you can borrow to see if you can replicate the problem?
Is this buzzing coming from the 'phones or does the box actually make noise you can hear?
It sounds like a bad connection in your headphone plug. I'd try another set of phones, If the problem continues, it may be a problem with the jack.
The Box itself doesn't make any noise. So as far as I can tell, it's only the Headphones. Unfortunately I don't have a pair of Monitors hear, so i cant tell if they would produce the noise as well.mikehalloran wrote: ↑Tue Jan 11, 2022 10:09 am Is there a PC you can borrow to see if you can replicate the problem?
So far I also tested the Interface on my Laptop and I am unable to recreate the issue after 7 hours time. So I am really not sure anymore, if the Problem is with the Interface.
I will try that. But why would it appear so randomly and also it's the second M2 Interface i got after I encountered the issue with the first one as well.
It just makes it less likely for me, for it to be a Hardware issue. I'll try it out regardless, thanks.
Just wanted to give an Update:
After testing out some things and not getting any result, I was close to buying a new PSU (Probably will do that anyway in foreseeable time, thinking about one from Seasonic), but before I did I switched my graphics card with an older one I still had here and so far, after more then 6 hours of runtime, no buzzing whatsoever. I am still careful with predictions but it actually seems like it was the GPU causing interference.
- Primary DAW OS: Windows
I have this problem too this must be the hardware issue . I have a good PC with a lot of ram
Thanks in advance
