Sorry to offer "annoying" advice. Have you installed the latest driver software? And, have you updated the firmware on the device itself. If the device is on the latest firmware, it will probably just say something like "You're up to date.".
There's a new option in the latest drivers to sync Windows sample rate. Without knowing what software you are running and how your system audio is configured, I would try checking or unchecking that. A background app or Windows itself may be switching something behind the scenes. If you are using the M4 for both Windows system and ASIO audio it's always good to set the same sample rate for everything.
DP 11.34 PT 2025.6 Mixbus 11 VEP 7.x with various VIs
MOTU M4 on MacBook Air M2 2023 Sequoia.5
CharlzS wrote: ↑Wed Jan 12, 2022 3:47 am
LOL I have no idea what you are saying Why life is so complicated
Exactly what should I do now
In the M4 Control App check or uncheck the sync to Windows sample rate option - try both settings. If M4 Control is not displayed, you get to it from the bottom right Windows notification area - right click the M and select Show. As far as how your apps and system audio are configured, you might want to check the forums for those apps.
