DP 11.02 track meter
Torbin
Post by Torbin »
Hello, when I open my old DP 9 projects in DP 11.02 none of my track meters on mixing board show audio representation on the individual tracks. The blue audio visuals on the track meters are missing. I can still hear the audio, just the visual representation is missing. I spoke with tech support and they suggested opening up a new project, loading the old project and setting it up with chunks. This works but takes a lot of time. I have lot of old projects I still work on. Anybody else not see the audio in the track meter?
Sincerely,
Torbin
DP11.33 Mac OS 15.3 Mac Mini Pro M2 10 core 32gb Apogee Ensemble thunderbolt. Started with Digital Performer in 2006.
Torbin
Re: DP 11.02 track level meter
Post by Torbin »
This post is regarding the track level meter not showing output on the fader. I am using DP 11.02 and Mac OS 11.6
Anybody have this issue?
Sincerely,
Torbin
Torbin
Post by Torbin »
Help. Anybody.
Tritonemusic
Re: DP 11.02 track meter
Post by Tritonemusic »
Do you have Fader/Meter checked in the Mixing Board mini-menu?
Torbin
Post by Torbin »
Thank you so much for your reply. I will check tonight to make sure, I haven’t noticed this before. So this maybe the issue.
Just to be clear, some projects have no visual audio output representation on the track level meter in mixing board or meter bridge. The sound is output/heard but no visual blue output moving in the meter. I close the project and reopen the project and it’s back.
Thank you so much again.
Will post back as soon as I check with your help.
Sincerely,
Torbin
I've had occasional "No visible meter" occurrences in DP, too. Seems like a bug, but I think I've only observed it twice on my rig.
HC Markus
https://rbohemia.com
Torbin
Post by Torbin »
Hi. Thank you both so much for your responses. It’s good to know I am not the only one who has experienced this. The result is time consuming when I have an artist at the microphone and I have to close and reopen a project to see the audio level in the track level meter on the mixing board and meter bridge fader. I have uploaded a really short video to YouTube showing the problem. It seems like a bug to me, but I just don’t know. It never happened to me before with OS 10 with DP9. Just started occurring when I upgrade to DP 11 and updated to OS 11.
Check the video if you have a minute please.
[YouTube] https://youtube.com/shorts/9l9FWd_h-wA?feature=share[/YouTube]
Sincerely,
Torbin
Torbin
Post by Torbin »
Tritonemusic wrote: Tue Nov 09, 2021 8:35 am Do you have Fader/Meter checked in the Mixing Board mini-menu?
Hi Tritone, thank you for taking the time. I do have Fader/Meter and Fader Readout checked in the mini menu.
Best,
Torbin
Tritonemusic
Torbin wrote: Tue Nov 09, 2021 6:39 pm
Best,
Torbin
Sorry I didn't have a solution for you, Torbin. I just saw your video and now I understand your frustration. If you ever get it figured out, please let us know. Good luck.
P.S. Have you tried trashing DP preferences? Might be worth a try.
Torbin
Post by Torbin »
Hi. Yes that’s the first thing I did. Trashed preferences. Lol
andyafco
Post by andyafco »
I've had this same issue. Have seen it a handful of times. I usually close and reopen the project and its fine, but its annoying. It might be a conflict with another plugin too, not sure.
Torbin
Post by Torbin »
Thanks Andy. For your response.
Sincerely,
Torbin
Are you seeing this in DP 11.04?
Torbin
Post by Torbin »
mikehalloran wrote: Sun Jan 30, 2022 11:32 am Are you seeing this in DP 11.04?
Hi, I’m sorry yes. I am currently working in 11.04. I updated and still the same issue.
Torbin
Dark Goob
Post by Dark Goob »
I'm seeing the issue on DP 11.1. Really freaking annoying!!!
-=DG=-
_________
Vocals/Synths
Sawblade Painter
https://soundcloud.com/sawbladepainter
Moonbase Zeta
https://soundcloud.com/moonbasezeta
_________
2021 MacBook Pro 16" M1 Max, 64 GB RAM, 8TB
MOTU 896HD (Black Lion Mod) | MOTU 828 Mk II | Korg X2, RK-100S Mk 2 | Yamaha Electone 7000 | Behringer ARP 2600 | Alesis Photon X25 | iPad Pro 12.9" | Line6 MobileKeys 49 | SoundCraft Delta 200 16•4•4 | DP8 & DP11
