Loss of one function in the SE window of DP11 SOLVED
waterstrum
Post by waterstrum »
In the sequence editor window, I used to be able to click on the top bar of an audio part to get back to soundbites view.
Now I have to go to the mini menu and select soundbites to go back.
Slows down the work flow.
Still wondering if it is possible to assign key commands to the mini menu on an audio track in the SE.
When editing a track, I'm often going back and forth from Pitch to Soundbites to Bite Volume.. etc.
So much small clicking...
There must be a better way.
All is well
Re: Loss of one function in the SE window of DP11
I've experienced that in the past with earlier versions(s) of DP. Not happening in DP11 for me currently; clicking on top bar returns me to Soundbite Mode from Pitch Mode. Or at least it did lat time I worked in DP11. I've been in 10.13 lately on a different project.
I trust you tried a re-boot of your Mac?
And yes, it would be swell to be able to select mini menu items with key commands.
Note, however, you CAN access Bite Volume by clicking on the volume number at the lower left of each soundbite in Soundbite Mode; this brings up the pop up fader that allows adjustments to be made.
HC Markus
M1 Mac Studio Ultra • 64GB RAM • 828es • macOS 14.73 • DP 11.34
https://rbohemia.com
fdco
Post by fdco »
waterstrum wrote: Tue Aug 24, 2021 2:25 am In the sequence editor window, I used to be able to click on the top bar of an audio part to get back to soundbites view.
Sure, use the Edit Previous/next Type.
Default keycommands ⇧→ and ⇧←
Mac Book Pro M1 32gb -2TB,
Apogee Symphony Thunderbridge,
DP11, MTPAV, Linnstrument, Chapman Stick
Tritonemusic
Post by Tritonemusic »
fdco,
I'm sorry for the off-topic question, but is that double-neck in your avatar a Mosrite?
fdco
Post by fdco »
Tritonemusic wrote: Tue Aug 24, 2021 9:51 am fdco,
Yes, It's the Joe Maphis model
fdco wrote: Tue Aug 24, 2021 9:27 amSure, use the Edit Previous/next Type.
Thanks for that!
Personally, I'd like to have direct access to, especially, the Pitch layer, as I use it a lot and am toggling back and forth between it and Soundbites as I edit vocals. But it's a good start!
waterstrum
HCMarkus wrote: Tue Aug 24, 2021 9:58 pm
Thanks for that!
I agree. I've been using the "previous/next" commands too and it is still several button pushes to get to the editor I want.
Also... still asking about the click in the top bar of the soundbite. HC, you mentioned that is is working for you in DP11, but said in other versions of DP it didn't.
Is anybody else experiencing this behavior in DP11?
Re: OT...
The Mosrite double neck is very cool!
How heavy is that thing?
All is well
Tritonemusic
fdco wrote: Tue Aug 24, 2021 9:52 am
Nice, thanks.
I wasn't clear in my earlier message; clicking at the top of the Soundbite returns to Soundbite layer from Pitch layer in DP10.13 for me. I encountered the issue raised at some point in the past... I don't recall specifics, other than it was resolved.
HC Markus
waterstrum
HCMarkus wrote: Wed Aug 25, 2021 6:23 pm I wasn't clear in my earlier message; clicking at the top of the Soundbite returns to Soundbite layer from Pitch layer in DP10.13 for me. I encountered the issue raised at some point in the past... I don't recall specifics, other than it was resolved.
It always worked for me in DP 10.13 and prior versions.
It stopped working in DP11.
I'm trying to figure out if it is something in my system, or a change in DP11.
All is well
fdco
Post by fdco »
waterstrum wrote: Wed Aug 25, 2021 1:25 pm Re: OT...
Pretty heavy, 5 kg I guess
waterstrum
Solved! Not sure how to mark this topic as solved, but thanks to MOTU tech support, it is fixed.
With the soundbite selected in the SE window, go to View/Show Only the Active Edit Type.
It should be unchecked.
In my case, it was unchecked, but required toggling on and off to get it working.
Some weird holdover from DP10.
I'm a happy camper.
All is well
As you say, All is Well! Excellent.
waterstrum wrote: Fri Sep 03, 2021 2:12 am Solved! Not sure how to mark this topic as solved, but thanks to MOTU tech support, it is fixed.
You started the thread, so you can edit the subject in the first post.
And you should. Although posts are difficult to find by searching this board, these topics show up on Google searches pretty easily. Marking things Solved helps others.
