Anybody using Audiomovers Listento with DP?
smashprod
Post by smashprod »
I've got to do a remote spotting session and would love to run Audiomovers' Listento plugin in DP instead of Pro Tools, but it's not supported by them. Anyone using it successfully?
Re: Anybody using Audiomovers Listento with DP?
No reason it should not work with DP; just not tested.
I have been planning to get on board with ListenTo, but I'm all shot up (Moderna) and haven't had a session that required it since I found out about it.
smashprod
Post by smashprod »
Thanks, but I'd like to hear from someone who's been using it reliably before I base a spotting session with all the producers and director on it.
dix
Post by dix »
Off-topic possibly (sry), but Audiomovers for spotting? It doesn't do video does it?
smashprod
Post by smashprod »
It's a scripted podcast for Audible :)
Suggestion/request to smashprod: Try it out first. And please let us know how it goes if you do! It is a truly great concept.
And though it doesn't do video, dix, I've been reading folks often run a simultaneous Zoom session for that and have seen videos of it in action. You can adjust latency to get very close to the Zoom video latency so clients can follow right along.
https://rbohemia.com
smashprod
Post by smashprod »
Don’t have time to be a guinea pig on this one. I will run the session in PT.
rawrooo
Post by rawrooo »
FWIW I use Listento 1.03 in DP all the time, works great with no issues at all.
I haven't tried the newer version, I didn't want to risk it not working and becoming a hassle. Not because of anything about the new version, I do that often with most software when I'm busy.
rawrooo
Post by rawrooo »
HCMarkus wrote: Wed May 12, 2021 4:26 pm Suggestion/request to smashprod: Try it out first. And please let us know how it goes if you do! It is a truly great concept.
I've done this. It's a bit clunky to setup but once it's straightened out it's cool. I had my two bandmates sitting in remotely on a mix session. There are videos on YT about how to set it up.
