Drag and drop files to the Clips tab window.
lulukom
Post by lulukom »
Hello !
If there are connoisseurs of the Clips tab here, tell me if it is possible to drag several files from the Context Browser to the Clips track at once, but only all files onto one track, i.e. vertically. When I try to do this, the files are laid out horizontally, i.e. one file per track. It seems obvious to me to have such a possibility, otherwise I have to drag and drop one file on each track. Thank you.
CharlzS
Re: Drag and drop files to the Clips tab window.
Post by CharlzS »
Don't have anything to test this with right now, but did you try using a modifier key with the drag, i.e cmd-drag or option-drag?
lulukom
Post by lulukom »
Unfortunately these combinations don't all work (as well as many others I've tested).
lulukom
Post by lulukom »
I want to clarify my question .. The problem applies only to MIDI files, which do not want to be dragged "vertically" into the Clips window. Audio files are dragged as I want, ie vertically.
