I just upgrade to DP10.13 from previous version, but now when I try to drag any Clipping on the arrange screen DP10 crashes immediately.
Back to the previous version, everything works fine.
Anybody can explain me why does it happen?
DP10.13 Crashes by dragging any Clipping.
- Tritonemusic
Re: DP10.13 Crashes by dragging any Clipping.
Which actual window are you referring to when you say "arrange screen?"
I had a couple of crashing issues with projects created in versions prior to 10.x and creating a new empty project then 'loading' all the crashy projects chunks into the new project solved the problems. Something to try.
I've had this problem in every version of DP since 9.
I still have it now in DP 11.03 and Big Sur.
Drag anything from the tracks window to a clipping window and 9 times out of 10 it will crash DP.
Does anyone else see this?
OSX Big Sur (latest). Mac Pro Late 2013 ("trash-can"), 3.5 Ghz 6-Core Intel XeonE5, 64GB RAM. Motu DP 11.31, Vienna Pro Server, Presonus Notion, Osculator, Keyboard Maestro, Tanqueray or Bombay Sapphire.
