Hello
I can not seem to get MIDI Learn to work
I have a Novation Impulse 61keyboard/controller.
I activate MIDI Learn, click on the element of the Clips View I want to make an assignment on then press the pad/key on my controller which correctly shows whatever pad I have pressed on the controller, then I press escape to exit MIDI learn and attempt to then "use" that control and nothing happens.
Anyone know what is going on ? clearly the controller is sending MIDI correctly to DP10 and the MIDI Learn function is populating the relevant parts of the Learn Settings window/dialog with the correct data but its not working at all when I then press that pad.
DP 10.11 MIDI Learn does not work ?
Re: DP 10.11 MIDI Learn does not work ?
My experience with Clips is very limited, and I am also on a Mac, but I can't get it to work, either. Perhaps someone can enlighten us before we call it a bug.
828x MacOS 14.5 M1 Studio Max 1TB 64G DP11.32
Managed to get this sorted thanks to MOTU support.
Had to enable the "Master Master" MIDI control..
Thanks for posting this. I would never have thought this, as it is still possible to attach controllers with the Master Master unchecked. You might want to mark the topic "Resolved".mfny wrote:Managed to get this sorted thanks to MOTU support.
