Can't access the Movie window mini-menu... [RESOLVED]
Re: Can't access the Movie window mini-menu...
Thanks for that.
That is a great idea.
I'm having the problem on both my music Mac Pro and also my laptop, so I can trash all of that on the laptop and see if that is the issue.
Thanks for the suggestion!
Well I trashed all my DP preferences but that didn't work.
I'm out of ideas!
I'm out of ideas!
Once, when I was having intractable issues with Digital performer, I created a new user acct on my Mac and all was right again
Thanks again.
I'm going to try that right now.
My first attempt to use "emoji's".
Let the history books reflect this momentous event?
- chrisdm1978
Hey there, I have this exact problem, Mac Pro 5,1 10.14.6, Saffire pulse RX580, DP 10.11. Happens in all projects. This is troublesome not being able to get at the most important features for a video in DP! Have you had any luck resolving this?
Regards,
Chris.
Regards,
Chris.
Hey thanks!chrisdm1978 wrote:Hey there, I have this exact problem, Mac Pro 5,1 10.14.6, Saffire pulse RX580, DP 10.11. Happens in all projects. This is troublesome not being able to get at the most important features for a video in DP! Have you had any luck resolving this?
Regards,
Chris.
Totally zero.
I've tried trashing preferences, creating a new Log-In account, so many more things.
It is all work-around now.
Set Movie Start is a command, so you can do that.
Import movie audio is not, so I use MPEG Streamclip to strip ou the audio and import into DP.
Clear Movies is also not available, so what I doehwn I get a new edit is close the project, delete (or move to another folder) the old cut/movie, and then when you re-open the project, you get an error message saying DP can't find the movie, and you just pick the new cut/edit of the movie you are working on and load that.
This is really maddening, though???!!!
JSmith1234567 wrote:I'm having this problem too now.
Both on my Mac Pro running DP 10.1 and Mojave, and my laptop running DP 9.52 and High Sierra.
I wish I could offer you guys a solution to this issue. Interestingly, it appears Chris' system is, with the exception of the RX580 (I run a Gigabyte RX460), identical to mine.chrisdm1978 wrote:Hey there, I have this exact problem, Mac Pro 5,1 10.14.6, Saffire pulse RX580, DP 10.11. Happens in all projects. This is troublesome not being able to get at the most important features for a video in DP! Have you had any luck resolving this?
Not knowing what GPU JSmith is running reminds me that both you guys would be well-served to take minute and put a signature together with system specs. Although Chris' post includes relevant info, and JSmith's first post included partial info, if complete info is in your signature, readers won't have to search for it.
One question for Chris: How are you powering your RX580? it is my understanding that the card pushes what the Mac Pro can deliver via its two 6-pins plus PCIe power, Could this be an issue? I wonder what GPU JSMith is running... My RX460 sips power, needing only that provided by PCIe.
That said, the fact JSMith is encountering this issue across two very different platforms is puzzling.
Hey thanks! I'll add that.HCMarkus wrote:JSmith1234567 wrote:I'm having this problem too now.
Both on my Mac Pro running DP 10.1 and Mojave, and my laptop running DP 9.52 and High Sierra.I wish I could offer you guys a solution to this issue. Interestingly, it appears Chris' system is, with the exception of the RX580 (I run a Gigabyte RX460), identical to mine.chrisdm1978 wrote:Hey there, I have this exact problem, Mac Pro 5,1 10.14.6, Saffire pulse RX580, DP 10.11. Happens in all projects. This is troublesome not being able to get at the most important features for a video in DP! Have you had any luck resolving this?
Thanks HCMarkus...Here you go (I hope...I'll see when it is posted!)
JSmith...it worked! Only suggestion is add DP version #. But thanks for doing that, and good luck getting the subject issue resolved.
Have you started a tech link with MOTU? They might ask you to send them a project file.
One final suggestion: create a new Boot drive with fresh install of Mojave and DP. Last time I upgraded OS (to Mojave 10.14.6 -latest) on my 5,1, I started from scratch with a freshly-formatter SSD, installed Mojave and confirmed it was operational, then used Apple's Migration Assistant to transfer apps and data from my prior (Sierra) boot drive, which I retained for backup. Worked like a charm. Had to re-authorize DP and probably some other stuff I don't recall.
That's a good idea!HCMarkus wrote:JSmith...it worked! Only suggestion is add DP version #. But thanks for doing that, and good luck getting the subject issue resolved.
I think next OS move I'm going to try that.
I did that a few years back, and it was allot of watching movies while loading/re-authorizing software & plugins and settings files, but worth the effort I think.
I did create a tech-link for this, but it's still floating out there.
Don't overlook Migration Assistant. Takes awhile, but doesn't require monitoring while it is doing its thing.JSmith1234567 wrote:That's a good idea!HCMarkus wrote:JSmith...it worked! Only suggestion is add DP version #. But thanks for doing that, and good luck getting the subject issue resolved.
But wouldn't that add back in all of the possibly messed-up preferences, or not?HCMarkus wrote:Don't overlook Migration Assistant. Takes awhile, but doesn't require monitoring while it is doing its thing.JSmith1234567 wrote:That's a good idea!HCMarkus wrote:JSmith...it worked! Only suggestion is add DP version #. But thanks for doing that, and good luck getting the subject issue resolved.
Thanks again!
For me, everything went peachy with Migration Assistant.
If it doesn't work, you can start over from scratch with nominal time lost by simply re-formatting your new boot drive. If it DOES work, you just saved a LOT of time and energy.
If you set up a fresh boot drive, you could just install DP first (before running Migration Assistant or manually installing stuff), then run a trial to see if the Movie Window issue is resolved. If it is not, you could free trial install and run DP10.11 to see how it does before you put your system back together.
That is a great idea. I'll try it that way. Thanks!HCMarkus wrote:For me, everything went peachy with Migration Assistant.
