RENAMING A SEQUENCE
RENAMING A SEQUENCE
i'm dumping old 4 track songs into dp and since half the time i don't know what i want to call the songs i leave the new project with a generic name. how do i rename the project after i've dumped stuff and such?
MOTU 2408MK3 (PCI-424) / MOTU 1296 / BLACKLION MICRO CLOCK / PRESONUS M80 / FOCUSRITE OCTOPRE / FOCUSRITE VOICEMASTER PRO/ PRESONUS CENTRAL STATION / UAD-1 (2)/ WAVES Platinum / PSP All PLUGS / IK Multimedia (All of them)/ DIGITAL PERFORMER 7.22 / PEAK Pro 6 / MACHFIVE 1.2.3 / DUAL G5 2.0 w/ 5 gigs Ram - OS 10.5.8 / RODE NT1 / RODE NTK / SHURE 57'S / SHURE 58'S / AKG C1000'S / SENNHEISER 421'S / SEINNHEISER E602 / BLUE BLUEBIRD/ BLUE SNOWBALL / AUDIX D2 (2) / EVENT TR8'S / WHARFDALE DIAMOND 6'S
just change the file name in the finder (option+click) and the project folder name
I am a very happy DAD.
MacPro 3.33Ghz 6core-32g Ram-10T HDs-10.12.6-Dp-10.0.1.
Korg Kronos 2-Korg Pa4X-Ensonic TS 10-Korg T3-Yamaha Dx 7iiFD-Akai S3000xl-Roland JV 2080
Genelec 1031A with KRK 10S sub-Yamaha NS10m
ULN-2..Tubetech Lca2B-Avalon 737sp-HEDD 192-Lexicon PCM 90.
Soundcraft Sapphyre 28ch
yeah i know i can do that, but you can rename sequences within dp but why not projects? i can't even do a save as replace. oh well. thanks though.
Re: RENAMING A SEQUENCE
Because of the title of this post, it comes up when you search for "digital performer rename sequence".msmith92 wrote:i'm dumping old 4 track songs into dp and since half the time i don't know what i want to call the songs i leave the new project with a generic name. how do i rename the project after i've dumped stuff and such?
So let me answer that question here.
The easiest way to rename a sequence is to option click (Mac) on the Name in the Chunks list.
MOTU: Please put Rename into the right click menu, as per Track names in the Sequence window. I would like there to be more logic and consistency in where to find things in DP.
It couldn't hurt to have it in a dropdown, but frankly, that's a lot more effort than hitting the option key and clicking, IMO. Besides, that's kind of how it works across the entire OS, so it makes perfect sense.
If I were to complain about anything in that regard in DP it would be cmd-f. In all other programs it is the find key. In DP it's the "filter" key (by default, at any rate). Hit that and dismiss the the dialogue box by hitting the bottom right selection and all your data becomes invisible.
Now THAT really should change. Adding a rename to the dropdown? Maybe after I get chunk folders...
- waterstrum
Hey MLC
The command F thing has never come up for me, but thanks for the warning.
I'd hate to lose the visibility of data without knowing why.
The command F keystroke can be easily redefined for you right now.
Go to commands window and search for filter.
Clear the current assignment and replace with your choice.
What do you want command F to do in DP?
Find what?
Find what?
All is well
Thanks. I knew that.
