**Copy and pasting of automation has my "seal of approval". I can cut and paste VERY dense automation without issue.FMiguelez wrote:
REALLY??
That alone would make me get DP10 right now and sing loudly with delight!
So I take it you've put DP's mixing/automation new capabilities to severe tests with your mixes and you are happy about the result?
Does it work equally well when snipping heavily automated sections?
What about Waves' plugins? Do the numerical values shown in DP now show the TRUE values and not that numerical nonsense anymore?
What about RELIABLE automation reading?
That was one of your biggest pet peeves. Does DP10 now read your "brute-force - all-parameter - crazy heavy-handed" ( ) automation techniques reliably every time?
So do you put your TDH seal of approval regarding those issues, or not quite yet?
What little I've seen and heard about DP10 so far, it definitely seems like MOTU took a leap (not step) in the right direction!
** I am Very happy with the automation except for the new issue of strange results when dragging sections as opposed to copying and pasting
**No, snap shot still does not work on most 3rd party plugs unless one tabs through all numeric parameters BEFORE snap shot.
**As far as reading Waves data accurately, it is my understanding is that numeric patching of parameter has been partially fixed. One aspect reads correctly, one doesn't,t. I am not sure which.
** In 10.11, There is another issue where changing location points in loop mode glitches playback badly. This needs to be fixed. If one changes location points in any other memory mode, no glitch. In loop mode, terrible playback glitch.
**DP 10.11 is less efficient than DP 8.07. Tested beyond doubt on a new 2013 Trash can with a fresh install of everything. This means that going back to old, large files can be problematic. My solution is a B room stocked with older computers. The thing RUINING my older computers? Crazy authorization issues with older authorizor protocols and this new breed of "subscription based" authorizer, which is developers being irresponsible for users older masters. (another subject altogether).
** Play back glitch- sometimes DP won't play back the first moment of a file. It sounds like a pre buffering issues. Also, there are occasional weirdnesses when editing as the pre fill buffers switch to live mode. It would be really nice to be Able to shut off Next Gen pre gen 2 as many have requested.
**For all the flak I received stating this was an issue here at the forum, as if I was some sort of "outlier", I feel vindicated. As if MOTU finally changed it's automation programming, it shows it WAS broken or at least ill-designed. I was not crazy. If I was crazy, DP wouldn't have changed anything. (Well, I am crazy, but that's a different matter altogether )
