Insanely useful Keyboard Maestro Macro
- Prime Mover
I thought I'd share this simple but helpful KM Macro I created. This allows you to move the DP playhead by Ctrl-Clicking anywhere, instead of having to find the ~10px vertical region within the ruler.
http://www.ericbarker.com/dropbox/Place ... k.kmmacros
Behinds the scenes: on Ctrl-Click the script gets the current mouse loc, clicks the mouse up in the playhead region of the ruler, then returns the mouse back to its original location. This all happens instantaneously, so it's barely noticeable. It works in the Tracks, Sequence, MIDI, and Drum tabs, and is relative to the DP consolidated window, so the window can be moved anywhere. It would need to be modified if you are using the compact transport controls, or some different window configuration.
To use any other key as a modifier key (like "I-click" for I-beam in DP), I have a slightly different version of the macro I could post if anyone is interested. But I figured "Ctrl-Click" or "Option-Click" (as it could be easily modified to), will work for most people
— Eric Barker
Eel House
Eel House
Re: Insanely useful Keyboard Maestro Macro
Thanks for posting this. My first attempt to download Safari added an .xml extension for some unknown reason. I did a "Download As..." and it seemed to work.
This does seem quite useful. I've gotten used to finding that ruler zone, but they don't make it easy. Thanks for sharing the fruits of your labor!
Prime Mover, thanks for sharing this. I cannot seem to download the macro from your link. I also tried doing as a "Download As..." per stubbsonic's suggestion but I just get that .xml link. Is there something I'm missing here or is there another link to the KM file you created? I look forward to trying it. Thanks again!stubbsonic wrote:Thanks for posting this. My first attempt to download Safari added an .xml extension for some unknown reason. I did a "Download As..." and it seemed to work.
iMac 20,1 10-core, 3.6Ghz, OS10.15.7, 128GB RAM, DP 10.13, VEP7
- spitfire31
This is a great macro, so useful and works perfectly – thank you very much for sharing! And for inspiring me to dig deeper in Keyboard Maestro.
Kind regards,
Joachim
Kind regards,
Joachim
If it were easy, anybody could do it.
- SMS
FYI after downloading, it had an .xml extension after the .kmmacros extension. Just remove the .xml and it will open in KM.
I had to edit a bit, it was clicking too high... likely has to do with window options... but it works well, Thanks!
MOTU user since Performer™ 1.22 on 128k floppy
DP 11.23
MacBook Pro 14” 2023 M2 max 12 core
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
DP 11.23
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
- Prime Mover
Glad some people got some use out of it! Dunno what's up with XML file, must have been generated by Safari, because i didn't put it there.
Just to let everyone know, I've modified it for my own use. Now I simply it the "0" on a number pad, without clicking at all. I figure, if I'm going to hold a key down to alter the mouse click, why not just have the key run the feature.
I think MOTU would get some serious praise if they added a "playback tool" to the tools palette, with similar shortcut. Someday I'll get off my lazy ass and write them a formal suggestion.
— Eric Barker
Eel House
Eel House
- SMS
It will be useful to me, but I locate using the 'dot trick' 99.9 of the time. It's 2nd nature, and I'd certainly not be able to sacrifice the "0" key to run the macro. Gonna try your 'modifier-click' trigger and see if it has benefit. Thanks again!
DP 11.23
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
DP 11.23
64 Gb RAM
4TB SSD
OS 14.0 Sonoma
UAD Apollo 8
828 mk3 Hybrid
MIDI Express XT
Doesn't seem to like working with the MTrackpad 2. No a deal breaker and I might fudge with the macro to see if I can make it so. Thanks for sharing. It would be nice to avoid that navigation headache.
- Prime Mover
It may not be as useful as most as it is to me. My work is kind of unconventional. I'm going through single waveform tracks and making hundreds of minute edits then relistening to the cut to make sure it works. I'm flicking up the trackpad hundreds of times an hour, and my wrist definitely feels it. I too can locate it about 80% of the time, but it's tiring. Also, on a 4K screen, that region is a bit smaller than it used to be back in the good old days.
MLC: I have a Magic Trackpad 2 as well. I can't imagine the type of pointer would make a difference. KM is simply simulating a click with whatever the default pointer is. It's very likely that people will have to change the click location depending upon their screen resolution. MacOS auto-resizes graphics depending upon the screen resolution, and it seems to translate differently to different environments.
If you need to test it, you can throw a pause command between the move and return commands so you can see where the mouse is moving to. Currently it does it almost instantaneously, so I have to look very closely to see it. The script does calibrate itself to know when you move the DP window vertically, but it may not be calibrated to your screen.
— Eric Barker
Eel House
Eel House
- spitfire31
I got the macro working almost immediately on my ancient (2013) MB Air. But now when I'm back in front of my iMac 2019 5K, I can't for my life get it to work in the latest KM. Maybe there's something to Prime Mover's suspicion that the macro isn't comfortable with a 5120x2880 Retina screen?
Still not able to get past the above mentioned issue in order to successfully download the KM macro from this link. Scratching my head since it seems to be working well for others. Any ideas on how to potentially remedy this? Thanks in advance for your suggestions.Rusty Shackleford wrote:Prime Mover, thanks for sharing this. I cannot seem to download the macro from your link. I also tried doing as a "Download As..." per stubbsonic's suggestion but I just get that .xml link. Is there something I'm missing here or is there another link to the KM file you created? I look forward to trying it. Thanks again!stubbsonic wrote:Thanks for posting this. My first attempt to download Safari added an .xml extension for some unknown reason. I did a "Download As..." and it seemed to work.
Looks useful but not working here after several attempts. I’ll try resetting each step to see if that helps.
