Undo MIDI edit
amplidood
Undo MIDI edit
Post by amplidood »
Is it just me or is DP not allowing me to undo MIDI edits in 10.11????
dix
Re: Undo MIDI edit
Post by dix »
A key command issue maybe? With 10.1 mine got messed up. I had to redo the Undo/Redo commands. Also, make sure the track isn't locked. Undo/Redo on locked of MIDI tracks causes permanent, undoable loss of MIDI data...a known issue that is to be fixed in a future update.
amplidood
Re: Undo MIDI edit
Post by amplidood »
Ah thanks, after the new install my lock column was hidden.
