RAM allocation in DP
- Primary DAW OS: Windows
Hello, all. Is there anyway in Mac Mojave to allocate more RAM to Digital Performer and specifically to the ARIA app? I have 40 gigs on my Mac, and my activity monitor shows only about 2% is being used when I play a sequence in DP. If I get too many voices loaded, it either refuses to load more, or I start getting playback problems.
I know that, eons ago, you could specify how much RAM was allocated to a particular app, but I was under the impression that that sort of thing was done automatically these days. It seems a pit to have all this RAM and not be able to use it.
I would appreciate any advice you nice people can give me on this.
Rick Averill
DP 10, Mac Mojave
DP 10, Mac Mojave
Re: RAM allocation in DP
I don't think RAM allocation is possible any more on a Mac.
Two things I don't understand:
1) 2% of 40G? that's 800 Meg?
2: your signature says you're using Windows
I believe you can change the RAM allocation on the ARIA "Settings" page. If you're using Kontakt, there are similar pre-load buffer size settings.
Thank you for your kind replies.
Regarding my signature, I have been migrating from Windows back to Mac, and had not changed my signature on this board. That has now been done. I apologize for any confusion that it might have caused.
Speaking of confusion, that's what I have regarding my RAM situation. In an attempt to be more specific about what I'm saying, I have posted a number of screen captures here:
https://photos.google.com/photo/AF1QipN ... 4Yz7im3U_X
It shows the resources of my Mac, the activity monitor while playing a DP sequence (if I'm reading it correctly, it shows less than 2% of RAM being used), and a couple of the error messages I get. I hope this is more explanatory of my problem.
Regarding the suggestion about changing RAM allocation in the ARIA settings, I'm trying that out. Thank you for that suggestion.
I just feel like 40G of RAM should enable me to do more. Again, any help will be much appreciated.
Rick Averill
DP 10, Mac Mojave
DP 10, Mac Mojave
Okay, I changed the RAM allocation in the ARIA stand-alone app to 128MB, the maximum it allowed. I saved that and then opened my sequence in DP. The instantiations I have of ARIA still show 512MB and for some reason won't let me change it there.
Rick Averill
DP 10, Mac Mojave
DP 10, Mac Mojave
I just had a chance to try this. ARIA AU plugin lets me choose a RAM allocation up to 16 Gs. Are you using the latest Player (1.959) and Engine (1.960)?Rick Averill wrote:Okay, I changed the RAM allocation in the ARIA stand-alone app to 128MB, the maximum it allowed. I saved that and then opened my sequence in DP. The instantiations I have of ARIA still show 512MB and for some reason won't let me change it there.
Thanks for responding. I'm using the ARIA app that I downloaded from Make Music last week. I'm assuming it's the latest one. Here is a screenshot.
https://photos.google.com/photo/AF1QipO ... bunmFDFXvf
It also shows where I'm trying to change the RAM allocation. I'm probably doing it wrong. Should I be doing it another way?
Rick Averill
DP 10, Mac Mojave
DP 10, Mac Mojave
Sorry, but your photos are 404 on my end. One needs to just click on the numerical field for a drop down menu.
That did it, cuttime. Thanks so much for your help.
Rick Averill
DP 10, Mac Mojave
DP 10, Mac Mojave
Today's Hero: Cuttime.
