Townsend Sphere L22 Microphone
miller325
Post by miller325 »
The the Sound On Sound review of the Townsend Labs Sphere L22 microphone states that it should work with any DAW as long as the DAW supports stereo-in/mono-out plug-ins.
Do DP 9 & 10 support stereo in/mono out plugins?
Any Sphere L22 and DP users on motunation?
iMac 4GHz Intel Core 7, 32 GB RAM, MacOS X 10.13.6, DP 9.52, Logic Pro X 10.4.4, MachFive 3, Live 9, Native Instruments Komplete 12 Ultimate, Universal Audio Apollo Thunderbolt
Nunu
Re: Townsend Sphere L22 Microphone
Post by Nunu »
Happy L22 user here ! Insert the Townsend plugin as a usual audio plugin in a track, & it works. If you recorded unprocessed tracks, you can still change every mic parameter at the mixing stage. I use the UAD system, which is very convenient for this.
www.nguyen-le.com
MacPro 2x2.8 Ghz Quad Xeon OSX 10.7.5, MacBook Air 1.7Ghz i7 OSX 10.8.4, DP 8.07, Orpheus Prism, MOTU Traveler, UA 2610, SPL GainStation, Thermionics Phoenix, Lexicon PCM80 & 70, Adam SX3V, SSL Sigma, Kush Clariphonic, UBK Fatso, A-Designs EMEQ2, Roland Integra7, Korg Triton 76, AxeFX II & XL, Neumann U87, Schoeps CMC5 x2, Mojave MA200, Geffel M930, Royer R121, Heil PR40, Audeze LCD2, UAD2, Reaktor, Live, Sibelius, Machfive II, Omnisphere, Trillian, Stylus RMX etc..
EMRR
Post by EMRR »
Yes, I use the AA Microphones PolarDesigner, the Lewitt Polarizer, and the Scheops PolarFlex plugs, all of which do that. I recall having another stereo-to-mono plug at one point.
The various Ambisonic decoder plugs also run in DP, the oddity I've encountered there is that SurroundZone works but must have all possible physical outputs assigned to function, even if you are using it to fold down ambisonic to stereo.
I haven't used a Townsend Sphere, but I do have Sennheiser MKH 800 Twin which I do a lot of dual mid side work with, and I built a dual output Neumann TLM67 out of multiple TLM67 electronics. The Townsend looks like it does the basic thing the other dual output mic plugs do, plus mic modeling.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
EMRR wrote:...and I built a dual output Neumann TLM67 out of multiple TLM67 electronics. The Townsend looks like it does the basic thing the other dual output mic plugs do, plus mic modeling.
Now that's just sexy talk.
EMRR
Post by EMRR »
https://groupdiy.com/index.php?topic=68096.0
Doug Williams
Tape Op issue 73
DP 11.34
