I'm currently on DP. 9.5. Is 10 stable on the current version of Windows 10? I don't want to be stuck with problems with my current projects. There are things I want in DP10, just wondering if I should upgrade now or wait a bit longer.
Thanks for feedback!
DP 10 problems?
- Primary DAW OS: Windows
Re: DP 10 problems?
Since upgrading to DP10 I haven't found any issues with stability. It's pretty solid.
Re: DP 10 problems?
The biggest bug I've found is with aftertouch, it records the aftertouch CC into the sequencer but does not play back that aftertouch . This is on OS X, but I would bet it's also on Windows.
Re: DP 10 problems?
I use one instance for each articulation to avoid any CC problems. However, I haven't encountered such problems on Windows whenever I ran tests. But, to ensure ease of mind when working on schedule, I've been using this method for quite awhile. Yes, it uses more tracks. I think for a lot of composers/producers, DP should include expression mapping in their next update to be on par with Cubase in that regard.
Re: DP 10 problems?
thanks for your comments!
