AU PlugIns Gone Missing
bdr
Post by bdr »
So...opened up DP 10 (Mac 10.11) this morning, having changed nothing since last using it, and it didn't load any audio units. After troubleshooting including searching here and trashing the suggested prefs etc, I feel DP literally does not see the components folder, so it isn't loading ANY audio units (it's loading VST and MAS with no problem). I have restarted, opened other apps (which still do see AU plugins) and am a little befuddled.
Any brilliant ideas gratefully accepted!!
Best
'Bewildered' of Melbourne
Mac 2.8 8-core, 20 GB RAM, Mac 10.9, DP 8, EWQLSO Platinum Play, Mach V II, Kontakt 5, Superior Drummer, AIR, Absynth 5, Plectrum, CronoX, Albino3, RMV, cup of tea.
Re: AU PlugIns Gone Missing
This is too weird:
viewtopic.php?f=1&t=66767
Sorry I don't have an explanation, but I think it benefits us all to get to the bottom of it.
bdr
Post by bdr »
cuttime wrote:This is too weird:
to add after reading the post...
-the plugins are all in the (components) folder, DP just doesn't see them. Nothing has been deleted.
-the plugins are all installed in the main library folders, not the user library
32-bit / 64 bit weirdness? Permissions?
Go to the preference in DP and see if the plugins are all disabled for some reason.
jimchik
Post by jimchik »
bdr wrote:So...opened up DP 10 (Mac 10.11) this morning, having changed nothing since last using it, and it didn't load any audio units. After troubleshooting including searching here and trashing the suggested prefs etc, I feel DP literally does not see the components folder, so it isn't loading ANY audio units (it's loading VST and MAS with no problem).
Likewise. And the best MOTU Tech can say is that I/we need to restore the Mac to before it happened, or update to 10.13...
A couple of Macs, a couple of iPads, an M6, DP, Vienna Ensemble Pro, tons of other stuff… but unfortunately all in the box… other than the M6, no outboard to speak of.
primeevolutionary
Post by primeevolutionary »
I am having this same problem in 9.52.
It just happened today and in the middle of using DP. I noticed that my controller no longer was in sync with DP and DP wasn't reacting to the controller.
I stopped DP with the spacebar and attempted to use Control Surface Setup to get the controller back in line and no go.
I closed the Project and reopened and DP telling me that it could no longer find AUs that were in use.
I rebooted. Same thing.
I went to Preferences > General > Audio Plug-ins. Only MAS and VST plugins are showing. Checked to make sure the plugins are still in their folder. They are.
This sucks!
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
primeevolutionary
This thread seems to be on top of this problem:
viewtopic.php?f=1&t=66786&p=567315#p567315
OS X 14.7
DP11.32
Stage-B16
2 828 mk1s
MTPAV USB
