Hey thank you SO much!dewdman42 wrote:I'm on 5,1 Mac Pro, that is not the trashcan, that is the last cheesegrater.
Here are some results of tests I did this week. It started out as a test to compare VEP7 to VEP6, but ultimately turned into a test of LogicPro vs Cubase vs DP, both with and without VepPro7.
First, VEP7 performed worse then VEP6 on OSX Sierra. After a week of experiments from VSL, I updated my OSX to Mojave and VEP7 definitely runs faster then VEP6 on Mojave. I am attributing that to Metal support in Mojave and VEP7 must be taking advantage. The main performance issue I was having with VEP7 on OSX Sierra was related to the GUI... if the VEP7 GUI was showing, it would add 10% cpu and if hiDPI mode was on, it would be another 10% cpu above that! But with VEP7 on Mojave it performs better then VEP6 ever did, including with the GUI showing, HiDPi and all the rest.
Also, I did a GeekBench test on Sierra just before the upgrade and afterwards under Mojave and it scored multicore score 20% higher on Mojave (~25,000).
So I'm quite pleased with Mojave...and VEP7 also on top of Mojave, but not on top of Sierra.
Now back to the question about DP performance.. The above testing led me to test out LPX, Cubase10 and DP9/10 using exact same project tracks and plugins, both with and without VePro7 to see how they fare.
Full spreadsheet here: https://docs.google.com/spreadsheets/d/ ... sp=sharing
You can read more details about the testing that was done, how it was done and summary:
https://www.logicprohelp.com/forum/view ... 80#p737261
but suffice it to say, DP10 did not perform as well as DP9. DP9 alone was slightly better performance then DP9+VEP7. Not enough difference to matter I would say. Use VEP7 if it adds convenience for workflow improvements, it will not make much difference in terms of track count and things like that, in my opinion. I did not try DP10 without VEP7, its a lot of work to setup the test project and I ended up removing DP10 before I did that test with DP9, and I don't plan to try again, but you can always check back to the above image link on google sheets to see if I do later.
In the above test I also had to bump the audio buffer up to 2048 for the DP alone test to get the performance I got. LPX won't go up past 1024, so I couldn't do a true comparison, but truthfully when using VEP+DP or VEP+LPX, the latency gets increased by VEP to something more like 2048, so I wanted to set it there for comparison. The performance in DP alone with audio buffer at 1024 was slightly worse then shown above, something even closer to the same performance as when using DP+VEP7.
That is really incredibly helpful.
I have been stuck in Sierra after a disastrous attempt at upgrading to High Sierra awhile back.
I did upgrade to VE Pro 7 without really thinking about it and whether there would be a performance issue.
Your info gives me the confidence to go Mojave / Dp 9.52 (I'll have to regress from 9.54) / VE Pro 7.
I'm on a "trashcan" Mac Pro, but I'm guessing that might take advantage even more of Mojave.
Well enough about me...let's talk about me.
No seriously, I appreciate your reply and the time you took to put it into a straight ahead explanation for us.
Thanks again!
