Well, this one is really odd.
Saving the current project in DP 10.01 turns on the metronome. Doesn't matter whether the Metronome button is pressed or not, doesn't matter if I save via keyboard command or via pull-down menu... in all cases the result is the same. Pressing "1" on the numeric keypad (RTZ in DP) or starting the sequence (space bar) stops it.
Is anyone else seeing this? As often as we all save, I'd expect you haven't or there'd be a thread already....
10.01 - Saving turns on metronome??!?
- Gravity Jim
Jim Bordner
Re: 10.01 - Saving turns on metronome??!?
Whoa. Nope. Never scene anything like this. ...it sounds like something from one of my recurring technology anxiety-dreams!
I'm guessing, if it's only happening on one project, Loading the sequence(s) to a new one would fix it.
Could you have ⌘S assigned to Click On in the Commands window? I believe the default is ⌘5.
