DP10 - Multiple issues
amplidood
Re: DP10 - Multiple issues
Post by amplidood »
Reassign Continuous Data crashes me every time.
dix
Post by dix »
amplidood wrote:Reassign Continuous Data crashes me every time.
Yup. A known issue that is said to be fixed in the next update. ....c’mon update!
MichaelAshSharbaugh
Post by MichaelAshSharbaugh »
miditime wrote: I also notice iLock cloud does not seem to work with DP10 - I had to transfer licenses to a usb iLok -
This is what I thought this post was going to be about. Did You figure out the Waves license problem? It's doing nearly the same to Me: all but 2 of My Waves plug-ins can no longer be found in DP10, even after having successfully utilized them hours earlier. Any suggestions?
(I am using MAC Sierra and a mixture of Waves v9 and v10.)
~ Michael
  • Apple Mac Pro [mid-2012] [Westmere] [model: A1289] [EMC: 2629] [5,1] | | CPU: 2 x 3.06GHz 6-Core Intel Xeon | RAM: 40GB | GPU: XFX AMD Radeon RX 580 GTS Black Core Edition 8GB GDDR5 -~-
    -~- MAC OS X: 10.14.6 [Mojave] -~-
    -~- DP version: 11.3 -~-
    -~- MOTU 1248 MOTU 2408 | MOTU MIDI Express XT | MOTU MIDI Express 128 | MOTU MTP / AV | MOTU Video Timepiece | MOTU MicroBook -~-
remmet
Post by remmet »
Had anyone else noticed that when you open certain Region commands, the cursor may or may not be sitting where you want it to be, so you have to use your mouse or the tab key to get it there? There seems to be little consistency where the cursor appears when you open, for example, the Transpose, Change Duration, etc, windows. And sometimes it isn’t there at all; you have to click to make it appear. It’s a little thing, but annoying.
R
Mac mini 2018 3.2GHz i7; OS X 15.2; 64 GB RAM; DP 11.32; Apollo X6; Kontakt; Omnisphere II; Adagio Everything, Spitfire almost Everything, Berlin Winds and Brass, Xosphere 2, and endless other sample libraries, acoustic and electric guitars, and assorted other essentials that have helped make me the "almost break even guy" my accountant so admires.
Gravity Jim
Post by Gravity Jim »
I'm seeing a lot of these same problems. This is a point-oh release after all... one of the tech guys at MOTU says that 10.1 is coming shortly. Here's hoping these troubles do the usual thing and blow away.
Jim Bordner
dix
Post by dix »
remmet wrote:Had anyone else noticed that when you open certain Region commands, the cursor may or may not be sitting where you want it to be, so you have to use your mouse or the tab key to get it there? There seems to be little consistency where the cursor appears when you open, for example, the Transpose, Change Duration, etc, windows. And sometimes it isn’t there at all; you have to click to make it appear. It’s a little thing, but annoying.
I’m not seeing these issues. The curser is never not there when using these commands on my system.
Hallelujah. I’m looking forward to actually using DP10!
DP 10.1 Sounds binary to me!
Just a heads-up that Brainworx's new Oberhausen synth has MIDI-learn issues in DP9 and PA tech support can't even find the plugin in DP10.
Anyone planning on buying it should wait for an update.
Michael Canavan
Post by Michael Canavan »
MLC, Monkey Man and dix, all joined Motunation at 10.01PM! :shock: :shock: :shock:
Obviously this means the earth is flat and 10.1 is dropping on tax day! :lol:
Michael Canavan wrote:MLC, Monkey Man and dix, all joined Motunation at 10.01PM! :shock: :shock: :shock:
No, it's the time they all staggered out of a Melbourne bar.
MANY members are listed as having joined at that hour. I'll tell ya, it was one helluva a party!
dix
Post by dix »
Like how the Three Stooges enter through a doorway at the same time.
And what, exactly, did you think MLC stood for?
Moe, Larry, and Curly!
Michael Canavan
MIDI Life Crisis wrote:MANY members are listed as having joined at that hour. I'll tell ya, it was one helluva a party!
I just noticed I also joined at 10:01PM! :shock: :shock:
Obviously the moon landing was staged. :roll:
Must've been a good party I don't remember a thing! :koolaid:
remmet
Post by remmet »
Moon landings aside, I found another issue with DP 10, and like several others issues I've brought up, some seem only to apply to my system and some are shared. What I just discovered is that pitch bend value 0 (zero) seems not to be recognized. More fun!
R
