Deleting "missing" plug in automation
- ghobish
In the Sequence Editor, Is there a simple way of deleting all the automation lanes of a missing plug in from an old session? Or do I have to do each lane one by one? (I don't want to delete all automation data because not all the plugs are "missing.")
Gary Hobish
A. Hammer Mastering & Digital Media
San Francisco, Ca
http://ahammer.com/mastering
Mastering: Mac Studio M1 MAX 2TB SSD, 64GB RAM, 32-core GPU, OS 12.6; DP 11.22, Waves, Izotope RX10 Advanced, Alloy, Nectar, PSP stuff, Plug-In Alliance, Metric Halo ULN-8 MkIV, Euphonix MC Control & MC Mix, Presonus Central Station, and (still) no air conditioning (but at least now there is airflow)
Annex: Mac Pro 2010 5,1 3.33GHz 12-core, 80GB RAM, 10.14.6, DP 11.22, Metric Halo ULN8 MkIV, MOTU 2408III
San Francisco, Ca
Re: Deleting "missing" plug in automation
Select a single occurrence of the data and double click. All points should select, then just hit delete. That also works on all data, including notes.
If you want to get fancy, you can use the search and select feature to delete specific types of data.
Or you could just call a friend... lol
- ghobish
That does streamline the one-by-one lane removal process.
Thanks, stranger. (Who was that masked man?)
Gary Hobish
San Francisco, Ca
San Francisco, Ca
- Shooshie
It would be nice if there were some way to show the audio automation you want in a single window, as with MIDI, and perform operations on the revealed types of automation data, only. The MIDI Editor does this, and always has, but no such feature that I know of for the Sequence Editor. Yes, that would be nice, indeed.
Even working in MIDI, it's not always easy. Those little lines of data get so tangled and confusing, so quickly if you deal with more than a few of them. Even if their icons are easily identifiable and contrasting, I find that about 4 strings of automation are all I can handle at once, visible in the editor, and if they are similar in values, even that's too many. Maybe going lane by lane isn't so bad, after all. But for erasing a lot of plugin data, it does seem like there should be an easier way.
- Primary DAW OS: Windows
Did you try using search?
Edit -> New Search
Time: All Time
Event Attribute: Event Type -> Choose
You'll get a big window w/ every conceivable data type in DP. Pick and choose all the kinds of automation you want to delete, search, and then delete them.
In this case, it might be easier to specify which ones you want to preserve using the "All Except"
Hope that helps!
Edit -> New Search
Time: All Time
Hope that helps!
DP 10 - Win 10 - Ultralite AVB
MIDI Life Crisis wrote: If you want to get fancy, you can use the search and select feature to delete specific types of data.
