MIDI takes ( keyboard short cut) can anyone help
rangerx
Post by rangerx »
i like D10, but do miss the MIDI auto takes , from what i read its only audio that has this option to do takes on the fly , is there a keyboard short cut for this , or a work around in DP
Mac min 16 gig, Mac pro 6.1 64 gig
Kawai VPC1 ,Nektar P6, Maschine Studio, 2 Mascjine Jam
Motu 828 es, acer touch screen t272hul. 3 Asus monitiors
ITS A GOOD DAY FOR A SMILE !
Re: MIDI takes ( keyboard short cut) can anyone help
I haven't tried this, but as per the manual p240, you can change takes on a MIDI track while recording. So you could presumably assign the key command "New Take" to a MIDI note or switch that you could hit on each pass to get to the next take. Or just press cntl-alt-N if that's convenient.
rangerx
Post by rangerx »
thank you wish they can address this , but they did plenty at the moment with dp10 , bravo the improvements
rangerx wrote:thank you wish they can address this , but they did plenty at the moment with dp10 , bravo the improvements
I agree. It's odd that DP doesn't have the option to just increment the take with each pass in cycle record mode for MIDI as it does for Audio, especially given the emphasis placed on making MIDI and Audio work the same way.
sonus
Post by sonus »
This is something I've been asking for years!
It's so counterproductive not having new (MIDI) takes added automatically while in cycle mode and I can't, for the sake of me, understand why they haven't implemented it yet.
MacPro 5.1 2x3.46 twelve core, 64Gig, OSX 10.15, Mac Studio Max 32Gig, DP11.13, RME HDSPe FX, Softube Console 1 & Fader, UAD-2 quad, Soundtoys v5, UVI Falcon 3.0, GForce Mellotron & String Machine , Waves Rennaissance...
rangerx
Post by rangerx »
cant be that hard a few lines of script and a tool added, main reason i use DP as my second daw
sonus
Post by sonus »
rangerx wrote:cant be that hard a few lines of script and a tool added
That's how it seems at least, given also that this is how it works with audio.
Apart from this (and probably a couple more) omissions and some minor bugs which I'm sure they'll be fixed in the next update or two, I must say that I'm really happy with DP10!
What an efficient, deep and mature tool we have in our hands! Kudos to MOTU for this great update!
dazzjazz
Post by dazzjazz »
Has this been implemented, if so - can someone please walk me through it?
Darren
iMac 27" 2013 24 GB RAM
OSX Catalina. Focusrite Clarett 8Pre. Heritage Audio HA73.
DP10.
Yamaha CP4. 1961 Hammond A100. Too many Leslies.
Darren Heinrich
BMus (Hons) Jazz Piano
PhD Jazz Organ Improvisation
http://www.dazzjazz.com/
dazzjazz wrote: Fri Nov 20, 2020 4:50 pm Has this been implemented
No. If you cycle record on a MIDI track your options are to overwrite or merge. The workaround would be to create a lot of MIDI tracks and arrange them in order in the Tracks window, set up a cycle and record on the first track. For each cycle you could press the down arrow so the next track is armed for that pass. You could also assign a MIDI Note to the down arrow in the Commands window so you can use your controller to advance through the tracks. Each of your takes now appear as separate MIDI tracks, rather than takes in one MIDI track.
There is no comp tools to use to assemble these MIDI tracks. You'd have to use the basic cut/paste/delete etc., to assemble the events you want in a comp track.
