AVB Remote Preamp Control via MIDI/OSC
cereboso
Post by cereboso »
Is anybody successfully controlling the preamps on an AVB device via MIDI or OSC?
Are you using a physical MIDI controller or MIDI via your DAW?
What setup are you using to do it and how is it going for you? Easy to use or a hassle?
ovinas
Re: AVB Remote Preamp Control via MIDI/OSC
Post by ovinas »
Works for me.
Novation LaunchControl/Korg nanoKONTROL 2 --> OSCII-bot --> UltraLite AVB
MacMini Late 2012 - Windows 10 Pro 1809
MacBook Pro Mid 2014 - macOS Mojave
Studio One 4
UltraLite AVB
Blueband
Post by Blueband »
I've got the same hardware, and I've found the OSCII-bot software on the Cuckos site. How did you set it up? Do you have a script set up?
tiomalo
Post by tiomalo »
I need that also guys how did you setup that. For mac and mackie umc. Just do i need to put simply connect MIDI cable wirh avb and mackie? Can i extend also avb to use more MIDI such as external MIDI switch?
