MIDI Express 128 and Windows 10.10
tdonta
Post by tdonta »
Hello, does MOTU have a driver for the MIDI Express 128 that works with Windows 10? After the upgrade, Cubase 10 Pro, Native Instruments Komplete Kontrol and Kontakt, and Finale no longer show the device as a routing option. I have used it the past several years to DAW control 4 racks of Eurorack modules.
thanks, - Ted
tdonta
Re: MIDI Express 128 and Windows 10.10
Post by tdonta »
To update: I had a pretty quick response from MOTU tech support. The latest Windows 10 update did disable the MIDI Express128 from showing up in Cubase Pro 10, as well as in Native Instruments Komplete Kontrol and Kontakt.
I was given instructions on how to find and modify the MOTU drivers permissions, and it all works again.
I use the Express128 to send MIDI control signals to 4 racks of Eurorack modules using Cubase. It all integrates easily, so I can use all my digital DAW controlled virtual instruments with the racks of analogue modules.
Blubby.blub
Post by Blubby.blub »
Having problems with a MIDI Express 128 and Micro Lite under Windows 10.
Running the latest drivers.
Sometimes they both show up in Device Manager but the Express 128's inputs/outputs do not function.
This worked until a few weeks ago, maybe a Windows 10 update broke them. I've changed all USB Root/Hub power settings to disable suspend, that got it up to working on some boots but failing intermittently.
I tried to create a support ticket but got web site errors, so posting here.
