First post here, I'm quite new to Motu and pro audio.
I've been using MiniDSP for active crossover and now boarded the pro-audio bandwagon
I bought a 1248 and it doesn't work the way I intend.
I can get music coming out thru window (using Motu Pro Audio) but the loop-back feature I attempt to do ain't working. I need such for having a PC based crossover do the work (EIKO)
http://www.lupisoft.com/ekio/
thru simple youtube as a sound source, here is a screenshot of my issue.
I get sound out to the motu but the return doesn't record anything despite the 1248 showing that signal is being sent...
On the "motu 1-24" in playback or recording, it never work. Only "motu pro audio" work and it only work to send signal out.
https://ibb.co/cRzWoL
I've tried asio mode too but same problem arise.
I get sound sent to the motu (seen thru the 1248 bar graph) but the loopback doesn't work and EIKO software doesn't see any signal at it's input.
I try to do the same as described here
http://www.lupisoft.com/ekio/articles/c ... annels.htm
Any help would be greatly appreciated.
Martin
