how to set the default input of a new audio track?
macbook pro 10.10, 2.5G,16G ram,256G SSD
- Primary DAW OS: Windows
Re: how to set the default input of a new audio track?
Pretty sure it defaults to whatever is at the top of your Bundles list.
Hit Shift+U and drag whatever you'd like to be the default to the top of the list.
DP 10 - Win 10 - Ultralite AVB
What I want is to have the audio track's input as NONE (no input) as default...mesayre wrote:Pretty sure it defaults to whatever is at the top of your Bundles list.
I really wish there was a way around this too!
I'd like my add-a-track output to default to the master stereo bus, but there is no way to make DP do that.
DP's add-a-track defaults to the top track in the hardware-outputs section of bundles.
You could do it with clippings or add similar track, but you have to remember to do that instead of just hit add-a-track.
I can't tell you how many times I've added a track, it defaults to the main L/R hardware output, and you hear it playing back but it doesn't get printed to the stereo mix.
OSX Big Sur (latest). Mac Pro Late 2013 ("trash-can"), 3.5 Ghz 6-Core Intel XeonE5, 64GB RAM. Motu DP 11.31, Vienna Pro Server, Presonus Notion, Osculator, Keyboard Maestro, Tanqueray or Bombay Sapphire.
Instead of using Add Track, use the Create Tracks item from the Project menu (Shift>Command>C).
This window allows you to add any combination of tracks with specified inputs and outputs. You can also specify that the newly added tracks will have specific insert settings applied.
Dave
Dave
I like to drag audio from Finder into DP tracks view , and it will generate new audio track, how can I have that dragged generated audio track's input set to none as default?magicd wrote:Instead of using Add Track, use the Create Tracks item from the Project menu (Shift>Command>C).
Dave
Wow... we're really getting into the weeds here.
Simple to fix after dragging all your audio in...rockman413 wrote:I like to drag audio from Finder into DP tracks view , and it will generate new audio track, how can I have that dragged generated audio track's input set to none as default?magicd wrote:Instead of using Add Track, use the Create Tracks item from the Project menu (Shift>Command>C).
Dave
Select the subject tracks by Shift or Command Clicking on Track Names in Tracks Window
Studio Menu>Track Assignments. (or Option A)
Bulk assign Inputs to "none"
Oh man, you mean I gotta actually press a couple of buttons? I WANT INSTANT WHAT I WANT WHEN I WANT IT!HCMarkus wrote: Simple to fix after dragging all your audio in...
Sounds like someone needs an emergency pancake infusion. Frodo?MIDI Life Crisis wrote:Oh man, you mean I gotta actually press a couple of buttons? I WANT INSTANT WHAT I WANT WHEN I WANT IT!This is bogus, man! I'm gonna rewrite the code myself...
He’s no help. I might talk him into a beer & burger but no p-cakes. It’s. mystery.
Anything, however small, that saves time and doesn't take your mind away from making music is a good thing.
- FMiguelez
I definitely wouldn't mind having every new track automatically assigned to a preferred set of I/O.JSmith1234567 wrote:Anything, however small, that saves time and doesn't take your mind away from making music is a good thing.
Also, I wish DP would set sends in new tracks to be at minus infinity INSTEAD of unity!
This applies to newly created tracks manually, or automatic new tracks after importing a bunch of files into the TO.
Why? Because a couple of DP themes (like Plasma) show unassigned sends to be dark (except for the damed volume knob at unity) and this is very nice because it REALLy helps to avoid visual clutter and only see what's actually assigned and used.
This way, assigned sends jump at you easily (if you take the time to reset all the sends to minus infinity, where they belong).
I mean, this is not a huge issue for me, but if implemented, it would save us all some time in the long run. I'm also all for saving time and avoid unnecessary and repetitive actions when possible.
I've never understood the logic behind DP setting all the sends in new tracks to unity
Me either.FMiguelez wrote:I've never understood the logic behind DP setting all the sends in new tracks to unity.
