lower-case letter marker names in TO??
stringtheory
Post by stringtheory »
ok...if i create a marker and name it lower case letter "c", "i", "j", "k", "l", "r", "s", "t", "v", "x", "y", or "z" the name disappears from the TO. it still appears in other edit windows, and in the markers list, but not next to the little yellow pentagonal marker in the TO. i've checked a couple projects, and they're the same. other lower-case single-letter marker names appear, but as soon as i type in one of those lower-case letters and hit enter, it disappears. the upper-case versions of these letters work fine.
is it just me?? is there a reason for this - some conflict-avoidance thing?
restarting DP didn't fix it, i'll try rebooting later.
27" iMac 4.0GHz (late 2015), 32G RAM, OSX 10.13.6, DP10.01, UAD Apollo Duo TB, MTPAV USB (also 2021 14" MBP M1 Pro, 32G RAM, Apollo Twin Duo TB)
Re: lower-case letter marker names in TO??
No, it's not just you. I never noticed this before, but I can confirm it's happening here, too.
stringtheory
thanks. i submitted a tech link. maybe this will help spur them on a renovation of the UI...
stringtheory
MOTU confirms the bug, and has put it on their list.
