HI, I just received a refurbished 27" iMac with a wireless keyboard and mouse. I turned the iMac on and get the Welcome screen to setup my account but can't get any input from my wireless mouse or keyboard.....
What should I do.... Should I buy or borrow a wired keyboard.....
Is there some trick I am missing
I scoured youtube and apple support but can not find info that relates to this specific issue. Thanks, Fred
MacBook Pro (16-inch, 2019) 2.3 GHz 8-Core Intel Core i9 16 GB RAM OSX 12.7.1 Monterey
UAD Apollo Quad, some Waves, Soundtoys, Digital Performer 11.34, Reason 13, iZotope 11, and lots of real instruments to play.
Are the wireless units charged? They should charge by connecting via the Lightening to USB cable. This will also serve as a direct connection.
I think that the Magic Mouse is inoperable with the cable attached. The Magic Keyboard, however, will work (as will the Magic TrackPad II if you ever get one).
If you have an old USB wired mouse, that works, too.
Anyway, you may need to set up Bluetooth and let the iMac discover your devices once they have enough juice to connect (won't take long).
The Magic Mouse II & Magic TrackPad II will not work before El Capitán and I assume the same fot the Magic Keyboard (I don't have one).
I keep my old USB trackball connected and every once in awhile, that comes in handy. Option Boot sometimes misses the BT connection and wired saves the day.
DP 11.34; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1 2023 Mac Studio M2 8TB, 192GB RAM, OS Sequoia 15.4, USB4 8TB externals, Neumann MT48, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave IK-NI-Izotope-PSP-Garritan-Antares, LogicPro X, Finale 27.4, Dorico 5, Notion 6, Overture 5, TwistedWave, DSP-Q 5, SmartScore64 NE Pro, Toast 20 Pro
Thank you Mike! I ended up borrowing a wired USB keyboard from a friend and got in to setup the iMac that way. So far the keyboard and mouse that I got from the dealer aren't working
It's good to have friends Thanks so much for your help and advice!
