Digital Performer 9.52 released today
Just noticed it up at MOTU.com.
The release notes are here:
https://cdn-data.motu.com/site/docs/dp/ ... ReadMe.pdf
Mac Studio M1 Max, 64GB/2TB, MacOS Sonoma 14.7.1, DP 11.33, MOTU 828es, MOTU 24Ai, MOTU MIDI Express XT, UAD-2 TB3 Satellite OCTO, Console 1 Mk2, Avid S3, NI Komplete Kontrol S88 Mk2, Red Type B, Millennia HV-3C, Warm Audio WA-2A, AudioScape 76F, Dean guitars, Marshall amps, etc., etc.!
Robert Randolph
Re: Digital Performer 9.52 released today
Post by Robert Randolph »
And the duplicate MIDI bug for plugins has been fixed. :koolaid:
This one should make some people happy.
Fixed a bug preventing track folder hierarchies from being preserved when dragging a sequence from the chunks window into the tracks overview or sequence editor.
2018 Mini i7 32G macOS 12.6, DP 11.32, Mixbus 10, Logic 10.7, Scarlett 18i8, MB Air, macOS 14.6.1, DP 11.32, Logic 11
dix
Post by dix »
As will "Improved click stability in Countoff and Countoff-Wait modes." But because I haven't tried to use it in so long that I've forgotten what the problem was.
Tobor
Post by Tobor »
Seems snappier so far.
Of course, Check for Update Now shows that none are available. Again.
No biggie. Hoping it makes a little bug I found last night go away. Downloading away.
DP 11.32; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1
2023 Mac Studio M2 8TB, 192GB RAM, OS Sonoma 14.6.1, USB4 8TB external, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave
mikehalloran wrote:Of course, Check for Update Now shows that none are available. Again.
I wouldn't be surprised if MOTU delays triggering that notification until the initial burst of download activity slows.
You can’t go to the d/l page?
9.51 and 9.52 now crash within a few minutes of opening. Before I installed 9.52, this was not happening. I have no plugins running. All I did was load a new project with soundbites ... but I did that last night in a 5 hour session where I imported and did rough edits.
I'm going to restore my system to a few hours ago (thank you APFS) so I can get some work done.
I let it overwrite 9.51 and saw no problems, although obviously, it hasn't gone through the paces yet.
I found the culprit. I was working on an .aiff file that had been giving me grief last night and that turned out to be the issue. I've seen corrupt audio files cause problems before but never this—usually they just don't load. And why it never crashed 9.51 before I installed 9.52??? Hell if I know. I'll just chalk it up to one of life's mysteries.
Anyway, I stripped and rebuilt the header in TwistedWave and it now behaved. DP 9.51 stopped crashing, also.
I could have used QT 7.6.6 Pro, DSP-Q or even iTunes (but that would have taken way too long) instead of TW to strip and rebuild the header. QT and iTunes can only do one file at a time while DSP-Q & TW can do 'em in batches.
toodamnhip
Post by toodamnhip »
Mue automation bug fixed? Yes! Will try out now.
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
mhschmieder
Post by mhschmieder »
I've been confused by the numbering too, for this and the previous update. My signature lists it the way it appears in some release notes, but Get Info says "9.52" vs. "9.5.2" and the same was true of "9.51" vs. "9.5.1".
I won't have time to work with it in depth for another week (annual family visit coming up), but did launch it on a "hard" project as a sanity check, with no problems so far.
Strangely, when I printed the release notes earlier today, there was nothing specific for 9.5.2 vs. 9.5.
iMac 27" 2017 Quad-Core Intel i5 (3.8 GHz, 64 GB), OSX 13.6.6, MOTU DP 11.33, SpectraLayers 11
toodamnhip
Downloaded and installed. Opened current large mix file, Dp would only stutter. Terrible audio playback. Did a safe boot restart which cleans things up, tried again, no go. Only audio stutter. Buffers already maxed at 1024 so I even tried 512, no go. To me, 9.52 is a no go. I have to get back to work and have no time to debug. I will watch to see if anyone here similar has issues. I’m back to 8.07 for mixing large files, and 9.51 for MIDI mute work.
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
wvandyck
Post by wvandyck »
mhschmieder wrote: Strangely, when I printed the release notes earlier today, there was nothing specific for 9.5.2 vs. 9.5.
It seems reasonable to assume the new features and fixes would fall under a bold subheader.
In this case the 9.5.2 features are in a regular font underneath the bold font Relative pitch editing
Summary: The layout of the release notes needs to be reformatted for clarity.
Installed this new version over 9.5.1 and no issues noted so far. Will need to a large project this evening to how it perfrorns under pressure,
