Import Other DAW Key Bindings_Commands
Hi all ... My main DAW is DP bu I frequently have to use Pro Tools and every now and then, Logic Pro. I just did a search for Key Commands and the only entry dates back to 2001. Also, when I went to Import the bindings into my session, there didn't seem to be a way to save it as a separate file so that I cold use them as needed. I know that Logic can import Pro Tools Key Commands, I would think this was an easy add-on. Does it exist? Thanks.
DP 11.22, Mac Pro 14,8 macOS X 13.5, 128 GB RAM, Apogee Symphony I/O, Apollo x8p, UAD plug-ins, PSP, Waves Mercury, NI Komplete Ultimate 14, Spectrasonics, Hollywood Orchestra, Spitfire; Symphobia, Los Angeles Scoring Strings, True Strike, VSL, real violins, guitars, mandolins, pianos, drums, percussion & lots of other stuff...
Re: Import Other DAW Key Bindings_Commands
I’ve not heard that these are translatable and doubt they are.
I think key bindings reside in DP Preferences, so you might be able to make a copy of the Preferences folder and modify one with your alternate bindings, then swap as needed. Not sure whether you'd need to restart your Mac or just DP to have the alternate preferences take effect.
Would Logic or Garageband, or PT be able to read a DP plist? Then again I think he's on a PC so maybe it is possible. I suspect it's not as easy as copy and paste a list, especially since different DAW use different terms. What would PT do with a "Chunk?"
HI all - no, I'm a Mac user. I guess I accidentally posted this on the Windows site. I'll repost it under Mac. Seems like it would be an easy thing to do ...MIDI Life Crisis wrote:Would Logic or Garageband, or PT be able to read a DP plist? Then again I think he's on a PC so maybe it is possible. I suspect it's not as easy as copy and paste a list, especially since different DAW use different terms. What would PT do with a "Chunk?"
Sure, you can save or export the key bindings in DP -- it's in the mini menu. But these are not usable in other DAWs, and other DAW command exports don't work in DP. The command structure is not the same and many commands in one DAW don't exist in the other.
Being used to DP's commands, I have edited the key commands in Logic and other apps, but this takes a while, and ends up with only a little more than half of the commands being the same. I did manage to cover most of the transport and basic navigation commands.
There used to be some key command presets that let you get close to PT and maybe other DAWs in DP, and Logic has a PT preset.
I expect you can get a lot closer using one of the keyboard macro applications.
Agreed! MI'd suggest Keyboard Maestro as Quickeys hasn't been updated in many years and is basically dead in the water (although some parts of it continue to operate - however sporadically).bayswater wrote: I expect you can get a lot closer using one of the keyboard macro applications.
Just do it the hard way. Write 'em down and enter 'em in manually. It'll build character.
We don't need no stinkin' character!stubbsonic wrote:Just do it the hard way. Write 'em down and enter 'em in manually. It'll build character.
Didn't help me with character, but it did make the commands easier to remember.stubbsonic wrote:Just do it the hard way. Write 'em down and enter 'em in manually. It'll build character.
When I moved from Studio Vision to DP I changed a lot of DP commands to match SVP’s. It made the transition so much smoother. I’m still using some I’m sure but after all this time I’m not sure which.
Frank Ferrucci
http://www.ferruccimusic.com
