AIF to MP3 - What do you use?
I was wondering what everyone is using to create MP3's?
- chamelion
I use SoundConverter all the time - It lives on my dock. It's shareware, and I've never had a problem with it.
http://www.macmusic.org/softs/view.php/lang/EN/id/579/
Cheers,
Geoff
Cheers,
Geoff
"Don't worry,
be hoppy!"
be hoppy!"
Peak Pro is included with DP? Since when? I've purchased DP3 and then DP4. I can't find a copy of Peak Pro anywhere.
I'm currently using 4.1 and I'm planning to upgrade to 4.6. Maybe it will come with 4.6?
I tried SoundConverter. Looks cool! But I'm hesitant to pay $10 just to find out if it works. Do you know if they paid the money to use the good MP3 converter software? (I'm guessing they didn't). What's been your experience with the quality of the MP3 files.
Re: AIF to MP3 - What do you use?
Well, I guess everyone isn;t using the same things. I'm using EITHER DP export soundbites OR Quicktime convert.My cellphone (Razr) likes to play the Quicktime converts, but hates the DP converts.mitchman411 wrote:I was wondering what everyone is using to create MP3's?
Sorry, my syntax use was confusing. I meant to communicate that mp3 conversion is included within Peak Pro (which I already use for other file finishing). Plus, Peak Pro gives me many mp3 bit rate options and other stuff -- as does the LE version.mitchman411 wrote:Peak Pro is included with DP? Since when? I've purchased DP3 and then DP4. I can't find a copy of Peak Pro anywhere.
Huh? Since when does Quicktime Pro (I tried version 6 and 7) export as MP3? I hadn't checked in a while and you got my hopes up.MIDI Life Crisis wrote:the same things. I'm using EITHER DP export soundbites OR Quicktime convert.My cellphone (Razr) likes to play the Quicktime converts, but hates the DP converts.
It is silly that iTunes will create great sounding MP3's, but not Quicktime Pro. Too bad creating MP3's in iTunes is such a clunky process.
I stand corrected. I meant iTunes (thank you!) Quicktime does the MPEG-4 conversions. And yes, iTunes is darn clunky, but they did release a new version today (as well as a new Quicktime 7 version.) And I did check and Quicktime STILL doesn't export to MP3mitchman411 wrote:Huh? Since when does Quicktime Pro (I tried version 6 and 7) export as MP3? I hadn't checked in a while and you got my hopes up.MIDI Life Crisis wrote:the same things. I'm using EITHER DP export soundbites OR Quicktime convert.My cellphone (Razr) likes to play the Quicktime converts, but hates the DP converts.
- chamelion
If you want quick-and-easy, I still think SoundConvert is hard to beat. Just drag the file onto the app and it puts the converted file (in any format you like) next to the original file it the same folder. Works for me
Cheers,
Geoff
Cheers,
Geoff
"Don't worry,
be hoppy!"
be hoppy!"
You never answered my questions about it:chamelion wrote:If you want quick-and-easy, I still think SoundConvert is hard to beat. Just drag the file onto the app and it puts the converted file (in any format you like) next to the original file it the same folder. Works for me
"I tried SoundConverter. Looks cool! But I'm hesitant to pay $10 just to find out if it works. Do you know if they paid the money to use the good MP3 converter software? (I'm guessing they didn't). What's been your experience with the quality of the MP3 files."
But you're right, it does look like a good solution. I wish they offered a 30 day free trial instead of the 500k thing. But then again.....it's only $10!
Converting from AIF to MP3 AND retaining decent quality is pretty important to me....especially since we're charging our clients for the service. When the MP3 phenomenon first started happening, there were all kinds of MP3 converters out there. Some sounded great and some didn't. That's why I was asking for more details about the quality of the program.
But if you don't want to give me those details, I'll go ahead and roll the dice and spend the $10 and hope for the best
- chamelion
Hey Mitch, what can I tell you? I haven't put it through the wringer with technical analyses, but I use it for clients too - and often when there are time constraints, radio and TV stations will download them use them for airplay. To my ears they sound excellent, otherwise I wouldn't be doing this commercial
Cheers,
Geoff
Cheers,
Geoff
"Don't worry,
be hoppy!"
be hoppy!"
Audacity -
http://www.audacity.sourceforge.net
it's shareware but you don't have to pay anything to use it. Works great and even hosts AU plug-ins! Does plenty of simple audio editing as well.
One small niggle - if you are using a MOTU hardware device, like an 828 MK II, Audacity will switch the sample rate to 96khz. It doesn't save things out at 96khz, it just defaults to that for audio input, if you want to record into Audacity. The solution is simply to do your thing with Audacity, quit the app, then launch DP to "reset" your hardware.
Thanks Geoff, I'm going to go with your recomendation. Sounds like you use it for exactly the same thing I do. Except that in my area the local radio stations will ONLY accept MP3's (128k) for on-air use!
One last question though.....are you using it with Tiger/Quicktime 7?
Thanks again Geoff. I never would have found this simple, but elegant piece of software with out your help.
