You can add 1 or 2 pixels to it but it won't make a lot of difference -- I don't think there is a lot of this image being used to show velocities. It helps a bit to make them a colour that contrasts with the background. I used cyan on a very dark background.
Most of the DP screen is graphics that are generally zoomable, so it's often more effective to just use a different screen resolution, and then zoom out the parts you don't need to see so closely.
You can easily edit these files yourself if you'd like other colours for example. I use Pixelmator but I'm sure there are many other apps to edit a png.
Sorry for this enormous picture!
- Len DAW Mac Pro 6-core 2013 | 64Gb RAM | 10.11.6 | Metric Halo ULN-8
DP 9.5 | VE Pro 6 | Kontakt 5
Thank you all for your help, the largest it can go is pretty good, but I still think that motu should adopt some of these scale-able graphics to be native in DP.
Thank you all for your help.
Mac Pro 2X Dual Core 2.66Ghz-10.4.9-7 GigRam-828MKII-MTPAV-Ultralight MK3-Digi Performer6.01-PeakPro5.1-Reason4-AbeltonLive6-Virus Rack(Red)-ReMOTE 25 & 37 SL-Nocturn-Stanton Dacratch-PluggoPack-DimensionLE W/EmuProteusPack-Sylenth1-Discovery MAC-MX4-Rapture-Alpha-Octopuss-Automat-Automat1-TALbassline-TALUno60
mike_o wrote:I still think that motu should adopt some of these scale-able graphics to be native in DP.
Me too, but we've been asking for a while to no effect. So in the meantime, I'm using screen resolutions as a workaround.
The screen shot shows MIDI on a 27" iMac screen at 2560x1440. Velocity is almost invisible. On the lower shot, the MIDI editor is popped out onto a second monitor at 800x600 (maybe a typical resolution when the editor was first introduced). The note are about the same size, but the velocity icons are big enough to see and edit.
