I just want to report that, after following Mike Halloran's instructions, I am now happily running Finale 2012 in El Capitán.
Now I'll see if I can open these ancient Finale files... They're from the late 90s!
Thank you!
--------------------------- "In physics the truth is rarely perfectly clear, and that is certainly universally the case in human affairs. Hence, what is not surrounded by uncertainty cannot be the truth." ― Richard Feynman
It should work but, if not, head over to the support link I gave earlier. There are a number of issues with old Finale files that can get in the way, all surmountable.
DP 11.34; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1 2023 Mac Studio M2 8TB, 192GB RAM, OS Sequoia 15.4, USB4 8TB externals, Neumann MT48, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave IK-NI-Izotope-PSP-Garritan-Antares, LogicPro X, Finale 27.4, Dorico 5, Notion 6, Overture 5, TwistedWave, DSP-Q 5, SmartScore64 NE Pro, Toast 20 Pro
I had to use that one recently when I upgraded my work machine to High Sierra (required due to being a software developer and needing to see problems that our users see), as Oxygen XML Editor never got modified to use newer Java or to package Oracle's Java with the app (not sure why -- they have a huge developer team and I am a team of "one" plus occasional DevOps support, and it wasn't that big of a deal).
Apple keeps threatening to pull support, but Adobe also depends on Apple's Java 6 (which has dependencies on some OS core that Apple didn't hand off to Oracle), for some functionality in Illustrator (I think maybe some of the XML support). Java 9 (recently released) solves these issues but hasn't been widely adopted yet as it requires developers to make MAJOR structural changes as Java now uses modules, similar to the "dylib" and "dll" approach of Objective-C and C++.
As for Finale, probably they are using Java technology for Music XML related functionality.
As none of the mentioned apps use Java for GUI stuff, there's not such a strong need for the vendors to update those parts of their apps; hence the tendency for them to run into this issue unique to macOS where the vendor changed as well as the packaging and installation strategy (this was intentional, to avoid potential incompatibilities between Apple's and Oracle's Java as well as accidental deletion of one when installing the other).
Mac Studio 2025 14-Core Apple M4 Max (36 GB RAM), OSX 15.5, MOTU DP 11.34, SpectraLayers 11 RME Babyface Pro FS, Radial JDV Mk5, Hammond XK-4, Moog Voyager Eugenio Upright, 60th Anniversary P-Bass, USA Geddy Lee J-Bass, Yamaha BBP35
