9.5 save bug and errors
Timeline
Post by Timeline »
When saving while playing, the front half of crossfades are removed. Save in play broken!
When doing a complete track song edit, 9.5 inserts fades on the back half of every cut. VERY BAD!
Reported to MOTU. Please reproduce and report as well
Re: 9.5 save bud and errors
Timeline wrote:When saving while playing, the front half of crossfades are removed.
Not happening here.
2018 Mini i7 32G macOS 12.6, DP 11.32, Mixbus 10, Logic 10.7, Scarlett 18i8, MB Air, macOS 14.6.1, DP 11.32, Logic 11
I never use fades inside a track except for special effect—always crossing at the null point eliminates the need.
I tried a few cross fades on a test track to see if I could duplicate the problem. Nope.
Without knowing exactly what and how, I haven’t a clue here.
DP 11.32; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1
2023 Mac Studio M2 8TB, 192GB RAM, OS Sonoma 14.6.1, USB4 8TB external, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave
Timeline
Post by Timeline »
Not happening here.
Thanks. check all your tracks. Definatly happening here and the save time in play is long.
Timeline
Post by Timeline »
mikehalloran wrote:I never use fades inside a track except for special effect—always crossing at the null point eliminates the need.
Ok mike thanks for checking
No, all seems OK. But we seem to have a lot of issues in V9.x that happen consistently on some setups and not at all on others. Some of the automation lane issues early in V9 happened on my iMac and not on my MBP, using the same OS version.
Timeline
Post by Timeline »
bayswater wrote:No, all seems OK. But we seem to have a lot of issues in V9.x that happen consistently on some setups and not at all on others. Some of the automation lane issues early in V9 happened on my iMac and not on my MBP, using the same OS version.
Yep, thanks.
No one is saying that you aren't having a problem.
Timeline
Post by Timeline »
I know Mike. Other strangneses im having include seeing the bottom performance window ocasionally bounce near to overload and other tims completely silent. Changed drives and the same thing happens intermittently. I notice when first starting this large session i can go through the entire tune and the performance bar is like off. Weird!
FWIW, several folks I know with 12 core machines report various DP and Finale issues not seen on other machines. May not be a connection here but definitely a correlation as a general trend based on anecdotal observations.
philbrown
Post by philbrown »
I have a 12 core on 9.5, do a lot of crossfade edits and occasionally save while playing and I have not seen this. I have another issue (crash-on-quit), but not this one.
What is a "save bud"?
philbrown wrote:What is a "save bud"?
philbrown wrote: What is a "save bud"?
I thought it had something to do with beer.
828x MacOS 14.7.1 M1 Studio Max 1TB 64G DP11.32
MIDI Life Crisis wrote:FWIW, several folks I know with 12 core machines report various DP and Finale issues not seen on other machines. May not be a connection here but definitely a correlation as a general trend based on anecdotal observations.
From another thread:
Version 9.51 also introduces the following enhancements:
• Improved compatibility with macOS High Sierra 10.13.
Pitch shifting and time stretching will now function on older Macs.
• Fixed a crash involving old MAS plug-ins lacking standard language localizations
I wonder: Does DP 9.51 fixes anything else on older Macs? :?:
Timeline
Re: 9.5 save bug and errors
Post by Timeline »
:-D
Maybe i need to go up to next OS. Unfortunately, my ssd will not allow it. I thought staying on El Cap would be ok. The 12 core mod did include a 5.1 rom update.
