Can't Save projects on network drive
- Prime Mover
My boss bought me another mac (iMac), so I networked the MacPro with the iMac with a Thunderbolt 2 bridge. I decided that it made more sense in this particular case for the iMac to be the server with the drives attached to it. Most everything works okay, but for whatever reason DP8 refuses to save over or update project files. Every time it gives me a "Error -35 this volume doesn't exist", yet the rest of the network works fine and I have full permissions. I can "Save As" to a new file, but saving over an existing one is a no-no.
One thing that drives me nuts is that I can't seem to login to the network from the MacPro. I never have been able to make this work properly, with any computer. I click on the "Erics iMac" under the "Shared" category in Finder, and I get an empty screen. I click "Connect as..." and nothing happens, no login, no chance to establish myself as the administrator, nothing. Yet my network aliases work and I can connect via "Connect to Server", though that doesn't give me a login either.
It might be that I'm only logged in as a guest, and DP doesn't seem to like that (even though I gave everyone "read & write" privileges universally), but as I said, I can't get a user login to come up anywhere.
— Eric Barker
Eel House
Eel House
Re: Can't Save projects on network drive
Tell us more about the Thunderbolt 2 bridge and how it's connected. I'm unfamiliar with that. Is there any point where the network connects to USB 3 or FW drives? Any difference with those?
The Project file won't save, but what about audio files etc.? Are they showing up on the network drives?
MacBook Pro 9,1 (mid-2012 Core i7 2.3 GHz 4 GB RAM), OSX 10.11.3, Newertech Voyager SATA drive dock
MOTU: DP 9.02, Traveler Mk 1, 896 MkIII Hybrid, MIDI Express XT
Alesis AI3 optical interface, QS8, QS7, DM Pro, DM5, QSR
Mackie Controller and Extender (original MIDI)
Pro Tools 12
Pro Tools 12
It may be as simple as giving that drive your Admin privileges. This will give you permissions to write to that drive.
If you can see it, you do this through Get Info.
If necessary, viewtopic.php?f=4&t=63853
- Prime Mover
I gave everyone and every account admin privileges on that drive, then selected "Apply to all Enclosed Items". But when I Get Info from my Mac Pro (client), it always comes up "You have custom access".
As for the connection types: I'm having to Jury Rig some temporary connections until my 16TB RAID comes in the next few days, maybe things will change then. Currently I've got a 4TB G-Drive hooked up via USB3.0 to the iMac. The drive has Thunderbolt 2, but the iMac doesn't. The RAID will have Thunderbolt 3. Obviously USB3.0 is super slow by comparison, but I wanted to keep it in the same configuration in preparation for the RAID.
So I'm using USB3.0 to connect the drive to the iMac, then using Thunderbolt 2 (via a TB2/3 adaptor) to connect the iMac to the Mac Pro. The speeds between the two computers is quite fast... the drive, not so much, in fact, it sometimes fails some transfers ;/ It used to be hooked up to the Mac Pro directly, no problems there. I'm thinking of possibly just getting another Thunderbolt 2 cable for the time being and hooking the drive directly to the Mac Pro as it was before.
That said, this permissions issue shouldn't just go away just because upgrade to a faster connection, would it?
— Eric Barker
Eel House
Eel House
No but it can change.That said, this permissions issue shouldn't just go away just because upgrade to a faster connection, would it?
Make certain that you give yourself and Administrators Read and Write access. I've had it happen that one worked and the other didn't. Sometimes, giving one overrides the other — if that happens, go with Administrators.
If it still won't work, let Apple try per my other link.
- Prime Mover
As I said, this isn't even possible, I can't login to the server, I can only access it via "Connect to Server" and typing in: "smb://Erics%20iMac._smb._tcp.local", which doesn't give me a proper login box. So I think I'm only coming in as a guest.mikehalloran wrote:Make certain that you give yourself and Administrators Read and Write access. I've had it happen that one worked and the other didn't. Sometimes, giving one overrides the other — if that happens, go with Administrators.
Also, all this talk of drive speed is moot, I remembered I can't save onto the local iMac drive (from the Mac Pro) either. And that's a TB2 connection.
— Eric Barker
Eel House
Eel House
- Prime Mover
Ugh, so I worked with an apple tech and got the connections working, so now I can login. But it gives me the same error message. Here is what it looks like:
— Eric Barker
Eel House
Eel House
Does this error message come up just as you start a new project? Or can you work for a while (including making audio files) and you get this when you first hit Save?
Pro Tools 12
Pro Tools 12
