Playbak produces stuttering, clipping etc
Hey folks,
I know the trick to have several instances of the same sampler (for example using 4 instances of Kontakt or Bidule) to balance the load but I still have a lot of issues even with few tracks playing back.
My question is about memory and hard disk. Right now I have 13 GB of memory.
If I add 16 more GB (29 total) do you think it can make a difference?
Changing from 1GB TO 13 GB did not make that great difference to be honest.
Also, do you think where the samples are located can play a role? For example if the samples are in the main hard drive where DP is installed will that affect performance? Will an SSD solve the issue?
I list here some factors that I thong they may affect performance and please add more or correct me!
1)Amount of memory
2)Hard disk and samples location
3)having more instances of the same software
4)there is another track about 128 VS 256 or 512 buffer size(?)...but I am not sure what this means!
1)Amount of memory
Mac Pro 2X 2.66 GHz Dual Core Intel Xeon, Snow Leopard OS X 10.6.8, 13GB RAM/ DP 7.24/ Plogue Bidule/SWQL Symphonic Orchestra (Gold),Hollywood Brass(Gold), SWQL RA, SD2, Symphonic Choirs/KONTAKT 4, Cinesamples Hollywoodwinds
Re: Playbak produces stuttering, clipping etc
Why on DP 7.22 and not 7.24?
I could never run playback at 512 in DP 7 without experiencing problems. Double or quadruple the buffer for playback and see if that doesn't fix you right up.
Lower your buffer when recording to reduce latency—this means that you won't have a lot of playback tracks available for overdub.
DP 7 is a 32bit app. I know that Bidule can help overcome the 4G RAM access limitation but others will have to chime in with details (if they remember back that far).
I posted under windows forum! I should post it under MacOS!
Will the memory upgrade help though?
Moved it for you.Gate 13 wrote:I posted under windows forum! I should post it under MacOS!
Thank you!
So, do you think either upgrading to DP9 and/or buying a newer mac with more cores and processor power will have a considerable improvement in performance (I currently have a mac pro 1.1 (2007)...
Yes..lol. And don't forget a new audio interface.Gate 13 wrote:So, do you think either upgrading to DP9 and/or buying a newer mac with more cores and processor power will have a considerable improvement in performance (I currently have a mac pro 1.1 (2007)...
This is one of the last things people consider when faced with clicks, crackles, stutters, and pops.
But these symptoms can definitely be signs of a failing audio interface. I should know..I had an Apogee Duet (original one) go out after five years of reliable service. Audio would be recorded in sync but play back late. Audio cleanly recorded would come back with embedded clicks and pops in it. DP would stutter and the CPU performance meter would ping all the way to the red (and then flash on and off like a neon sign), with just a few tracks running. This was all due to my Duet failing. I replaced it and the issues all went away.
http://www.davepolich.com
