DP 9.1 Hang on Splash Screen [Resolved]
Re: DP 9.1 Hang on Splash Screen [Resolved]
7.24 will not install over Sierra as far as I can tell. Installing/uninstalling it will mess with a DP 9 install.
First, I would run the uninstaller for 7.24 and then put away the CD. Then trash and remaining v.7 Preferences.
Do a clean uninstall of 9 per the MOTU page.
Did DP 9 ask to authorize? Do you have a good internet connection or did you install a VPN or overly restrictive firewall? If DP can't see the license server the first time, it will never boot.
If still having problems, open Console. This should tell you where it is hanging. Either something is trying to load that can't or is loading that shouldn't. If the MOTU Mackie HUI plugins are failing to load, you'll see this in Console. Run the installer again and reboot.
dix
Post by dix »
Thanks Mike. Per the revised Subject, the issues is resolved. Bad MIDI driver (see previous post).
dix wrote:Success! Deleting the contents of the MIDI Drivers folder (Macintosh HD > Library > Audio) unclogged DP and all apps that use MIDI. I'm good to go! There were several old drivers in there that didn't like the new MBP and/or Sierra I guess.
Thanks again MLC! Your patience and wherewithal are exemplary.
Thanks. Now if you'll excuse me I'm off to post some completely inappropriate things on Facebook... :rofl:
waterstrum
Post by waterstrum »
FWIW,
Just had the 9.1 hang on splash screen and waited it out.
In my case it was Spectrasonics VIs.
Long time waiting and eventual force quit.
After 2 launches DP came back.
All is well
dix
Re: DP Slow to Launch
Post by dix »
[Just in case anyone else is having this issue too. I'm putting this tip here for safe keeping]
Launching DP on my desktop was, suddenly, launching very slowly with a big pause after the plugins went by on the splash screen. I happen to notice that the Configure Hardware default was, inadvertently, set to Built-In Audio. Since I have my built in sound playing through my 424 I didn't notice. Once I set it back to PCI-424 I again had normal launch times.
