Import track setup from another project
zandurian
Post by zandurian »
So I have a song using Superior Drummer and I have it set up multitrack with 7 aux tracks and effects on the aux tracks etc. and I would like to import the same 8 tracks (1 instrument and 7 aux) over to another song I'm getting ready to play drums on.
Seems that there was a way to do this but I can't figure it out. I know I can make them into a V-rack and import them that way but I'd rather have the tracks in the regular tracks window.
Advise?
Using DP8
Mac Pro (early 2009 - originally 4,1 - flashed to 5,1) 2 x 3.42 GHz 6-Core Xeon X5690, 64 gigs PC3-10600 RAM, OS 10.13.3, DP9.52, UAD2 duo, UAD2 solo,
Superior drummer 2, Mach 5-3, Ivory, PCIe 424, BL modded 24i/o, MIDI express XT, unisyn, Melodyne 2, Izotope RX2, Addictive Drums, Pianoteq
buzzsmith
Re: Import track setup from another project
Post by buzzsmith »
Does the new song already have recorded tracks or is it still empty?
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
The LOAD command should do that. If not, then I'd make a copy of the project and delete what you don't want. Maybe save the clean version as a template for future use.
davidh
Post by davidh »
I have a clipping which I use for this. The clipping consists of all my Superior tracks (empty MIDI tracks, the VI itself and aux returns). Works like a charm. Make a clipping of your custom Superior tracks from your old song project (including plugins but no MIDI note data). Then just drag the clipping from the clipping window into your new DP project.
Mac Pro 'Nehalem' 2 x 2.66 Quad Core, 28GB, 10.11.6 || MacBook Pro 2.7 Intel Core i7 Retina, 16GB, 10.11.6 || MOTU 2408 Mk3, 828 Mk 2, MTP AV || DP 9.51 & 9.13, Mach 5 v3, MSI, Ethno2, MX4, VEPro6, all Spectrasonics, Kontakt ... and many of the other usual suspects.
http://www.thekeyboard.co.uk
zandurian
Post by zandurian »
buzzsmith wrote:Does the new song already have recorded tracks or is it still empty?
Buzzy
It's and old song getting a drums facelift from the original DHFS to superior drummer 2.
zandurian
Post by zandurian »
davidh wrote:I have a clipping which I use for this. The clipping consists of all my Superior tracks (empty MIDI tracks, the VI itself and aux returns). Works like a charm. Make a clipping of your custom Superior tracks from your old song project (including plugins but no MIDI note data). Then just drag the clipping from the clipping window into your new DP project.
That's it! Thanks
davidh
Post by davidh »
zandurian wrote: That's it! Thanks
Cool :dance:
