Justin_K wrote:Thanks for the replay HC markus.
Did you watch the video? My questions pertained specifically to it. I feel your comments would be better suited to a DP discussion rather than in this general Mac thread.
Yes, I agree. Buffer size is important... as is RAM etc...
I watched that video some time ago, probably not long after it was produced.
Of course the video concepts apply to Macs!
They are computers, and are constrained by the same factors as all computers. Hence my comment re: buffer size. Unless this parameter is unavailable in your DAW, buffer size customization to the situation at hand will provide the biggest performance change, both in system responsiveness and ability to handle complex projects. Unfortunately, it is a balancing act with shifting fulcrum.
I have been running an all-SSD (SATA as opposed to PCIe) system for several years now and loving it. I haven't felt the need to go to PCIe SSD as yet. Moving to SSDs is great, and speeds boot and project load times. SSDs may help with real time performance as well, but won't impact performance once the data being operated on is residing in RAM.
RAM delivers data much more quickly than the flash memory used in SSDs. RAM is 1-2 orders of magnitude faster. As such, the more data you can keep loaded in RAM, the better your computer will function. If you want RAM to operate as fast was possible in your modded (12 core 3.33) Mac Pro, using it in two ranks of three 1333 sticks will maximize its throughput.
5,1 Mac Pros shipped with 1333 RAM even when paired with a Nehalem (1066 only) processor. As shipped, the RAM runs at 1066 because of the CPU. However, after an upgrade to a 1333-capable CPU, the RAM will run at 1333
after an NVRAM reset.
Interestingly, much RAM labeled as 1066 is
actually 1333. You might try an NVRAM reset; maybe your RAM is 1333! That said, the performance difference between 1066 and 1333 is reportedly 1-3%, so not a major factor.
Hopefully, the above will assist you Justin. If I am missing the point of your question, perhaps others will chime in with more pertinent information.
