Long standing selection annoyance in DP
amplidood
Post by amplidood »
I've never understood why selecting a soundbite in any editing window doesn't automatically create a new selection range. I can't think of a single instance in the way I work that I wouldn't want this to happen. Anyone?
Re: Long standing selection annoyance in DP
There is the option in the selection range pop-up to "Set to Selection Bounds" but it doesn't always seem to work with a selected soundbite. At least it was not consistent when I tested in the TO and the Graphic Editor.
Isn't there a key command to set the selection range to selection?
FMiguelez
Post by FMiguelez »
stubbsonic wrote:There is the option in the selection range pop-up to "Set to Selection Bounds" but it doesn't always seem to work with a selected soundbite. At least it was not consistent when I tested in the TO and the Graphic Editor.
Double-clicking with the I-beam cursor gets you the SB selected and its duration ready in a selection range.
You get it by pressing letter "i".
Double tap makes it stick (change tool), so you can just double click on the SBs as needed.
FMiguelez
Post by FMiguelez »
I´m not in front of DP now, but you can also get a selection range by clicking on a SB and pressing Shift-Command up/down arrow. This works as long as there's another track. I suppose the command would be something like "move selection to next track".
Not ideal, but you can get it quickly like that. Very annoying if you need to do that a lot.
amplidood
Post by amplidood »
FMiguelez wrote:I´m not in front of DP now, but you can also get a selection range by clicking on a SB and pressing Shift-Command up/down arrow. This works as long as there's another track. I suppose the command would be something like "move selection to next track".
Precisely. The double-click I-beam thing only works in the SE.
FMiguelez
Post by FMiguelez »
amplidood wrote: Precisely. The double-click I-beam thing only works in the SE.
The other one I mentioned works in at least the SE, TO and GE.
But I do hear your point. It should be "easier" to do...
But wait! The first one ALSO works in the TO. Same for the GE in the case of MIDI notes.
