Problem with Motu 2408 mk3 as standalone format converter
wm_b
Post by wm_b »
Hi, I'm new here.
I have had a 2408 for many years that has served me in many ways but most recently I've been using it as a format converter to go from ADAT to TDIF on one bank only. I've recently had a need to use more than one bank of ADAT to TDIF conversion but I cannot get it to work.
I have 2 ADAT sources that I'm interfacing with TDIF inputs on a Tascam DM3200. When I set the Source on the 2408 to ADAT A, B, C and input unique signals on those respective banks I can see corroborating signal indication in the TDIF signal meters below (below the ADAT input indicators). However, when I try to get this signal to present itself on the Tascam mixer it doesn't work. If I change the source on the 2408 to A, or B, or C then I see the whatever signal is present at the single source bank reproduced on all TDIF banks. I can also get this signal to come out of the Tascam mixer.
I know I am clocked correctly and that my mixer is setup to receive signal from the TDIF inputs. What I don't understand is that according to the 2408 user manual I should be able to use it in the fashion I've described. Am I doing something wrong? Does this work for anyone else? I bought this unit new in 2004 and it has never had any problems when I was using it with the 424 card.
Thanks for your input.
For the record, I'm using all this stuff on a windows computer.
EMRR
Re: Problem with Motu 2408 mk3 as standalone format converte
Post by EMRR »
I don't think I've tried to route two ADAT sources. There are quite a few posts about standalone mode, thought they may be hard to search.
Most are along these lines:
viewtopic.php?f=1&t=31472
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
wm_b
Post by wm_b »
[quote="EMRR"]I don't think I've tried to route two ADAT sources. There are quite a few posts about standalone mode, thought they may be hard to search.
Hi Doug, according to that post in the link it sounds like what I'm trying to do should work perfectly.
My source is set to ADAT A-C and my TDIF outputs are connected correctly but nothing is actually being output at all. I can only get converted output if I set the source as ADAT A or B or C. The indicator LEDs show what would be the expected activity for unique conversion across ADAT A-C but unfortunately there is no output.
I'm just trying to confirm that this feature is broken or incorrectly documented to exist.
