DP9 glitches all the time
holing00
Post by holing00 »
Hi all, any help appreciated!
My DP glitches every few seconds whenever i playback!!! I'm using DP9, running with Vienna Ensemble Pro and Kontakt within VEP. I have a big orchestral template but not huge (around 50-60 MIDI tracks). I'm using Macbook Pro with the processor 2.8 GHz Intel Core i7 and 16 GB 1600 MHz DDR3 memory. MBP was purchased half year ago. I have tried increasing the buffer size up to 2048 but it doesn't help. Have tried restarting everything, the project file, the computer. I just worked with a similar size project a week ago and nothing like this happened. Please help! :(
Re: DP9 glitches all the time
Define: glitches
holing00
Post by holing00 »
Have tried tweaking the setting in Kontakt 5 but it doesn't seem to help....
Are you experiencing drop out? Clicks? Hung notes? "Glitches" doesn't really say much about the problem. :roll:
There were VEP issues with DP9 that were supposedly fixed with later versions. Have you tried anything later than 9.0?
holing00
Post by holing00 »
MIDI Life Crisis wrote:Are you experiencing drop out? Clicks? Hung notes? "Glitches" doesn't really say much about the problem. :roll:
Everything would suddenly go off every few seconds :banghead:
holing00
Post by holing00 »
cuttime wrote:There were VEP issues with DP9 that were supposedly fixed with later versions. Have you tried anything later than 9.0?
my version is 9.1....
Thanks.
Try 9.12.
holing00
Post by holing00 »
it turned out when I remove audio plugin in all the chunks, it was finally running smooth...
Thank you all who helped :)
Was it one particular third party plug? If so which one? It might be helpful to other users to know. Thanks!
