Performance issue with tempo changes
Justin_K
Post by Justin_K »
I'm working on a piece using VEPro and LA scoring strings. Performance is ok, until I put a 'rall' in.
I always get pops and clicks, like I'm suddenly sapping the CPU.
What the heck?
Can anyone assist?
Thanks in advance.
DP 9.1.2
OSX 10.10.5
Mac Pro OSX 10.10.5
2 x 3.33 Ghz 6-Core Intel Xeon
42 GB 1066 MHz DDR3
DP 9.13
JSmith1234567
Re: Performance issue with tempo changes
Post by JSmith1234567 »
I have that problem too.
I just live with the clicks and pops until it's time to print the mix, and then I raise the buffers to like (1024?) and it prints OK with no clicks and pops.
Not an optimal solution, but at least you can print a mix.
OSX Big Sur (latest). Mac Pro Late 2013 ("trash-can"), 3.5 Ghz 6-Core Intel XeonE5, 64GB RAM. Motu DP 11.31, Vienna Pro Server, Presonus Notion, Osculator, Keyboard Maestro, Tanqueray or Bombay Sapphire.
Justin_K
Post by Justin_K »
Thanks for the reply. Good work around.
After doing more research, many people switch off "tempo sync' in Kontakt if you are using sounds that don't rely on it. I certainly alleviates the problem.
I'm now wondering whether downgrading Kontakt 5.6.6 to an older version might help.
Mac Pro OSX 10.10.5
42 GB 1066 MHz DDR3
DP 9.13
terrybritton
Post by terrybritton »
Justin_K wrote:Thanks for the reply. Good work around.
Whenever I see the words "VEP" or "Kontakt" I reflexively reach for the link to this great video by member Steve Steele. Let me know if it has any nuggets that helped you out with this issue, if you would!
Terry
MOTU 828 mk3 hybrid
FMiguelez
Post by FMiguelez »
That seems like a great video. I'll watch it in the evening. Thanks Terry.
Justin, this may be a long shot, but I wonder how dense your tempo ramps are?
You can make a rallentando with hundreds of points, or just a few. Have you tried reducing the density? I know you can do so with CCs etc., and they, cummulatively, can slow things down a lot.
Might be worth a shot. Won't take more than 2 minutes to check if it makes a difference.
Tritonemusic
Post by Tritonemusic »
FMiguelez wrote:Have you tried reducing the density? I know you can do so with CCs etc., and they, cummulatively, can slow things down a lot.
You beat me to it, FM. I was just about to suggest taking a look at "Thin Continuous Data."
Justin_K
Post by Justin_K »
Thanks for the replies everyone, and I'll definitely check out the video Terry.
FM, yes I have just simplified the density of tempo changes, and it has helped, thanks.
Also, I'm now working at the 256 buffer (an obvious tweak yes, but since I was observing performance issues in the most simple of setups, I discounted this tweak for a while).
thanks again, things are becoming more settled now.
Mac Pro OSX 10.10.5
42 GB 1066 MHz DDR3
DP 9.13
FMiguelez
Post by FMiguelez »
Good to know it's better.
But a 256 buffer is too small.
When mixing, definitely raise it as high as possible. That must've had something to do with your issue too, I think.
This belongs in the Troubleshooting section. Moved.
