Lyrics
- supersonic
Lyrics
Hi
Do you know if it is possible to move an entire arrangement with lyrics in quickscribe? Here on 9.12, when I move notes by a couple of bars forwards the lyrics stay behind.
Music is movement in silence
Re: Lyrics
I don't use QS at all but just thinking out loud, what happens if you make the move(s) in the MIDI or tracks window? Do the lyrics make be with the notes?
- buzzsmith
Re: Lyrics
I don't use QS, either, for lyrics but I'm kinda thinking that the lyrics are not actually attached to the notes as in Finale.
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Re: Lyrics
What? So what's the point? That's just plain useless.
Re: Lyrics
I've only typed lyrics a couple of times in QS and the lyrics are locked to notes. I recall that the space bar jumped the text cursor to the next note, also a dash would do the same.
I'm not sure whether you can directly import/export lyrics, but with careful text editing, you can bring them in from even a text editor as long as the dashes & spaces cause things to shake out. YMMV
- supersonic
Re: Lyrics
I read the manual in the End
. You can reflow the lyrics. In my case I moved my music 4 bars forward, selected the first note and chose reflow from the lyrics window.
- buzzsmith
Re: Lyrics
I stand corrected and good to know!supersonic wrote:I read the manual in the End. You can reflow the lyrics. In my case I moved my music 4 bars forward, selected the first note and chose reflow from the lyrics window.
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
