MOTU 8282mk3 FW LOUD POPS!
TheoKontonis
Post by TheoKontonis »
Hey guys!
This is my first post on MOTUnation!
Before four months I experienced a problem. While I was working on a project on Cubase Pro 8.5.5, suddenly I heard a LOUD POP from my monitors (Yamaha HS-50M) my MOTU 828mk3 FW immediately disconnected from MOTU Audio Setup and from Cubase and got burnt! I contacted MOTU Tech Support and got it repaired through its distributor here in Athens. Since that fact, my 828mk3 works fine but this LOUD POP persists! I hear it one to two times per day. Its frequency is random and it bothers me a lot. Since that I am in frequent contact with MOTU Tech Support and we can not find a solution! Could help me please? I do not know what causes this POP.
iMac 21.5 (Mid 2011), Motu 828mk3 FW, Yamaha HS-50M, Novation Remote 49 SL Compact, Waldorf Blofeld, Cubase Pro 8.5.5, Ableton Live 9.7, Various Plug-Ins.
terrybritton
Re: MOTU 8282mk3 FW LOUD POPS!
Post by terrybritton »
Do you have other interfaces on the same system?
That pop used to happen to me - it was from the system sync becoming unstable.
If you are using Firewire, switch to using USB instead. Once I did that my problems disappeared. Perhaps the connection is flaky with the Firewire cables they make us use (the 9-pin ones).
Terry
MOTU 828 mk3 hybrid
TheoKontonis
terrybritton wrote:Do you have other interfaces on the same system?
Terry
Hi Terry!
Thanks for your reply!
No, I am not using other interfaces on the same computer!
My 828mk3 is the FireWire model unfortunately and it lacks USB.
Today for example, it did not appeared...
Should I buy a power conditioner and have all my equipment attached on it?
Theodore.
TheoKontonis wrote:[Should I buy a power conditioner and have all my equipment attached on it?
Theodore.
YES! Especially if your AC supply is not solid!
terrybritton
TheoKontonis wrote:
Hi Terry!
Theodore.
A power conditioner would offer another layer of stability, for sure.
When I would use DeOxit cleaner on the Firewire ends and connectors, that often would make the problem go away for several days - even two weeks once. Also buying new cables would help. That is why I wonder if the connection is simply not very stable on Firewire cables. But I finally gave up fighting it and went with the USB, even though I was enjoying stacking two units for the inputs by daisy-chaining them for a while. But even used singly, the darn things would never be reliable with the Firewire. I hope you find a solution - I'd be keen to hear what you discover!
(I still have a ton of Firewire cables here!!!) :-)
Terry
MOTU 828 mk3 hybrid
TheoKontonis
Hi guys!
Thank you very much for your replies!
You helped me a lot!
Currently I am saving money to get a power conditioner!
I will try electrical contact cleaning, alternate cabling and report back soon!
Firewire has always been rock solid for me on an 828mkII. Advantage: lower CPU hit than USB.
TheoKontonis
Hi guys,
Lest has to do with my FireWire cable that is wrapped in order to be tidy?
Anyway, I am looking for a physical shop to get a Firewire 400/800 cable.
TheoKontonis
HCMarkus wrote:Firewire has always been rock solid for me on an 828mkII. Advantage: lower CPU hit than USB.
Nice to hear this Marcus! :D
TheoKontonis
Hi guys!
Today I bought a new FireWire 400/800 cable and connected the interface with the computer with it. For ten minutes now everything is fine! :D
terrybritton
Here's hoping with you that the new cable does the trick! :D
Terry
MOTU 828 mk3 hybrid
TheoKontonis
terrybritton wrote:Here's hoping with you that the new cable does the trick! :D
Terry
Hi Terry!
Thank you my friend! :D
TheoKontonis
Hey guys!
May I have your attention please? :D
I tried and changed my old FW cable with a new one. With the a new cable I was fine for two days. After these two days passed the clicks and pops came back. Then I tried and connected to my wall outlet an external outlet that filters the AC current and to this outlet I connect a multi outlet that in this going all my equipment. Again for two days I was fine. After those two days the clicks and pops are back again...
What should I do?
Thanks in advance!
TheoKontonis
Hey guys!
I tested with a FireWire to ThunderBolt adapter but I didn't find any luck... :(
terrybritton
Does this happen anywhere you might be? Or have all these tests been done in a single location?
The reason I ask is that power brownouts can also cause this to happen (pops, squeals, whistles) from the box losing sync due to a power fluctuation. The only cure is either be in a different location or use a power conditioner if that is the cause.
Terry
MOTU 828 mk3 hybrid
