UAD v9.0 - Any feedback?
UAD v9.0 is released with Sierra support and three new plug-ins API 2500 Bus Compressor, Chandler Limited Zener Limiter and A/DA STD-1 Stereo Tapped Delay. Some people complained install hosed their system. What is the feedback on stability? New plug-ins?
Krakadon
Rock, metal, Nashville, TN
* 15" MBP 2.2 GHz Intel i7 (Quad), 16GB RAM, 850 EVO 500GB SSD, 500GB 7200 RPM SATA, AMD Radeon 1GB, OS X 10.11.6
* Apollo Quad FW (FW9.0), UAD-2 Quad FW, UAD-2 Quad TB, M Audio Oxygen 49
* DP 9.12, PT 12, Amadeus Pro, DMG, FabFilter, iZotope, NI, Plugin Alliance, Toontrack, TB, UA, Valhalla, Waves
* Fractal Audio Axe-Fx II FW Q4, EBMM JP BFR7, EBMM StingRay 5, Ovation Legend 1866, Martin D1-R
* UA 4-710d, RNC-1773, Shure SM-57, SM-58, SM7B, Rode NT1-A
Re: UAD v9.0 - Any feedback?
Installed and it's stable... However I can't update to Sierra until BFD3 is working. So I am on the last version of Yosemite. Soon as FXpansion updates BFD3 I'll go to Sierra. This was in the release notes "This software is compatible with macOS 10.12 Sierra; full testing and qualification will arrive in early 2017. For the latest macOS Sierra information, review this KB article."
https://help.uaudio.com/hc/en-us/articl ... ility-Info
Take special care to remove the preference files as this will help remove conflicts from previous installations:
https://help.uaudio.com/hc/en-us/articl ... lo-silver-
waxman
- Gravity Jim
Works fine here under 10.12.1.
Jim Bordner
I'm on Yosemite 10.10.5. Running smooth here.
http://www.davepolich.com
Do I understand right though that this update isn't really for the UAD-2 series of PCIe cards and Sierra? That people like me that have those will need to wait?
You're good...James Steele wrote:Do I understand right though that this update isn't really for the UAD-2 series of PCIe cards and Sierra? That people like me that have those will need to wait?
Important: Install UAD v9.0.0 before upgrading to macOS Sierra. All earlier versions of UAD software, and UAD v9.0.1 software, are incompatible with macOS Sierra.
macOS Sierra Compatibility Summary
Apollo Thunderbolt (all models) Compatible
Apollo FireWire (1 Unit) Compatible
Apollo 16 FireWire (1 Unit) Compatible
UAD-2 Satellite Thunderbolt Compatible
UAD-2 Satellite FireWire Compatible
UAD-2 PCIe cards Compatible
Apollo FireWire (2 Units) Incompatible
Apollo 16 FireWire (2 Units) Incompatible
UAD v9.0.0 and UAD v9.0.1 are fully tested and compatible with released versions of macOS 10.9 Mavericks, 10.10 Yosemite, and 10.11 El Capitan. Full testing and qualification of macOS Sierra will arrive in early 2017.
waxman
Thanks! I can't even tell where you'd GET UAD v.9.0.1? The file I downloaded was "UAD-Mac-v900.zip." I assume that's okay. I need to think about what else might break under Sierra for me, however.waxman wrote:You're good...James Steele wrote:Do I understand right though that this update isn't really for the UAD-2 series of PCIe cards and Sierra? That people like me that have those will need to wait?
I have to add here that I really dislike how every time you run a UAD installer, it adds the UAD Meter & Control Panel to my Login Items list and I have to manually remove it. Ugh.
- buzzsmith
I was wondering about that!James Steele wrote:I have to add here that I really dislike how every time you run a UAD installer, it adds the UAD Meter & Control Panel to my Login Items list and I have to manually remove it. Ugh.
I've never done it before. How do you manually remove it?
Thanks...
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Open System Prefs > Users and there is a list called "Login Items" associated with your user account. Delete UAD Meter & Control Panel from that list.
- buzzsmith
Thank you!James Steele wrote:Open System Prefs > Users and there is a list called "Login Items" associated with your user account. Delete UAD Meter & Control Panel from that list.
Focal Twin6 Be(s)
Focal Twin6 Be(s)
There are a few more files to remove... all the steps are here....buzzsmith wrote:Thank you!James Steele wrote:Open System Prefs > Users and there is a list called "Login Items" associated with your user account. Delete UAD Meter & Control Panel from that list.
waxman
I may have misunderstood the question. It was not my intention to describe how to do an "uninstall" of the UAD software, but rather just to prevent the UAD Meter & Control Panel app from automatically running at startup.waxman wrote:There are a few more files to remove... all the steps are here....
What about the new plug-ins?
Krakadon
James Steele wrote:Thanks! I can't even tell where you'd GET UAD v.9.0.1? The file I downloaded was "UAD-Mac-v900.zip." I assume that's okay. I need to think about what else might break under Sierra for me, however.waxman wrote:You're good...James Steele wrote:Do I understand right though that this update isn't really for the UAD-2 series of PCIe cards and Sierra? That people like me that have those will need to wait?
UAD 9.01 is for Windows
waxman
