DP9 Transport Control issues - AKAI MPK261
Tyas
Post by Tyas »
Hello everyone,
I just installed my trial version of DP9, after it was strongly recommended to me by one of my teachers (after telling me it would suit my needs better than Ableton Live 9).
I'm digging it so far, but I seem to have a problem with controlling the transport controls (play/stop/record) from my AKAI MPK261 USB MIDI keyboard. And by "problem", I mean I'm wholly unable to do this. The strange thing is, the keyboard does register with DP9 - I can play instruments with it and it gives me back sounds, I can record with it, it works. Just not the transport controls.
I've looked around some for possible causes, but none so far have worked. Just to make things clear, this is what I've already done:
- The "Master Master" box in the Commands menu is ticked, as is the "Transport Master" box
- In the "Transport" section of this same menu, I have selected the MIDI Events for the play/stop/record buttons and pressed the corresponding buttons on my keyboard accordingly, to map them. This did register, and the MIDI Events boxes now show the proper button data (#118/#117/#119, respectively).
- My MIDI keyboard is properly routed and connected (since it does allow me to play and record)
- My MIDI keyboard does send out MIDI CC data
The physical buttons themselves are also not defective - they work perfectly in Ableton.
Any help would be greatly appreciated, since this does seems like a very promising DAW - but I am not down with taking my hands off the keyboard every time I want to hit play/stop/record. I'm sure I'm missing some button or setting somewhere.
-Tyas
Guitar Gaz
Re: DP9 Transport Control issues - AKAI MPK261
Post by Guitar Gaz »
Been there done that - it works with Reason but not DP - so it is abandoned gathering dust for now. Try all you might it won't work unless you have Reason or Ableton running in Rewire with DP. Of course it works as a keyboard but not as a Master controller in DP. If anyone solved this it would be great - doubtful though.
Gary Shepherd
____________
terrybritton
Post by terrybritton »
I gave up on the transport controls working, but have used the "DAW Control buttons" instead, as they can be set in the Edit menu of the MPK2xx to send PC Keyboard keypresses. Those work just fine with the Controller's settings. Too bad the keypad's "Enter" key is not in the MPK2xx's list, though, so I set the right-button to "Return" and changed the controller settings. Then changed the center button to "Num0" for stop, and etc. as matched some of the keyboard shortcuts I do use. The MPK2xx allows for a second "modifier" key to be used from the button press as well. Each preset of the keyboard can have its own setup.
Terry
MOTU 828 mk3 hybrid
terrybritton
Here is some more information on the Key assignments of the DAW control buttons:
Tip: The HID (Human Interface Device) protocol lets devices send typical computer keyboard keystrokes. USB game controllers are an example of this, acting as an alternative to your computer's keyboard. MPK249 also uses the HID protocol, letting you configure certain buttons to send your most-often used keystrokes to your software, so you no longer need to switch focus constantly between the computer's keyboard and your MPK2XX.
Key 1: If Keystroke is the selected Type, this determines what keystroke the Assignable Switch sends. The available keystrokes are 0–9, A–Z, F1–F12, Backspace, Return, Up Arrow, Down Arrow, Left Arrow, Right Arrow, Tab, various symbols ( , . / [ ] \ ' ; ), Esc, Insert, Home, Page Up, Delete, End, Page Down, and Num 0–9.
Key 2: If Keystroke is the selected Type, this determines what modifier keystroke (e.g., Shift, Command, etc.), if any, the Assignable Switch sends with the Key 1 keystroke. The available modifier keystrokes are None, Control, Shift, Alt, Option, Control-Shift, Control-Alt, Control-Option, Shift-Alt, Shift-Option, Alt-Option, Control-Option-Alt, Control-Shift-Alt, and Control-Shift-Option.
Manual downloads:
MPK249
MPK261
MOTU 828 mk3 hybrid
