bit meter
Phil O
bit meter
Post by Phil O »
Does anyone know of an inexpensive bit meter plugin that will work with DP 4.6? Spectrafoo has one in their package but I don't want to spend that kind of money for the whole bundle - all I need is the bit meter.
Thanks,
alphajerk
Post by alphajerk »
http://apulsoft.ch/freeports/index.php
is that what you are looking for? top one.
dual gHz, OSX 10.3.9, DP 4.6, PSP plugs [then a load of nice hardware]
Phil O
Post by Phil O »
Yes this does the trick. Thanks.
Tim
Post by Tim »
Phil O wrote:Yes this does the trick. Thanks.
Donate!
giles117
Post by giles117 »
Yes Donate. $10.00 bucks is worth this bit meter. I have needed one and refused to buy SPectrafoo.
DP 6.02
Euphonix MC Control
Phil O
Post by Phil O »
Actually, now that I've used it a couple of times, it doesn't do the trick. Sometime all 32 indicators ar lit and it seems to be locked in that mode. Other times, every fourth indicator is out and all the others are lit. Other times it works fine...All on the same file!
If I can figure out how to get it to work properly I will be happy to donate.
giles117
Post by giles117 »
Havnt experienced that yet. Which version AU or VST??? I've tried both (under VST Wrapper)
DP 6.02
Euphonix MC Control
azusa749a
Post by azusa749a »
Anybody want to buy my Spectrafoo Complete OS9 for cheap?
You can upgrade it to OS X for $149. I have no use for it now.
Ah..Lissajous phase scopes. :lol:
Phil O
Post by Phil O »
giles117 wrote:Havnt experienced that yet. Which version AU or VST??? I've tried both (under VST Wrapper)
I'm on a Quicksilver Power Mac dual 800 running the AU version. I don't have VST wrapper.
