How to print the command list
SchrodingersCat
Post by SchrodingersCat »
Probably an easy one; I've searched the manual and the forum and I'm hoping someone can respond with an simple one-liner: how do you print out all the commands that are listed in the <shift> <L> list?
Re: How to print the command list
File > Print Window
FMiguelez
Post by FMiguelez »
Do people still print things on paper? :shock:
One prniter I had was destroyed by my bad-temper and annoyance in a bad moment.
2 years ago, the other printer's cartridges were completely dried. I haven't bothered to replace them :lol:
SchrodingersCat
Bayswater - THANKS! Embarrassing to ask but that was very helpful.
FM- you are absolutely right. The shift L and type in the search box its just TOO EASY!
Not paper. But you can print to (searchable) PDF. Or put them in a spreadsheet showing alphanumeric keys on one axis and modifier keys on the other so you can quickly see unused key commands (there are thousands). Or to a text document you can edit to show only the more frequently used things.
SchrodingersCat
Actually putting the list into a spreadsheet is a great idea. :headbang:
I thought so. Here's an earlier version I did in Excel. It would need updating with a dump of the commands list in DP 9.
http://heavyethics.com/DPAV/DP%20Commands.xlsx
Look at the second sheet: Sheet 1-1. Some of the Mac keyboard characters in the last rows don't show.
This can be done with the use of the Lookup functions and Pivot tables using the first sheet which is basically a copy and paste of the print file from DP.
Phil O
Post by Phil O »
Shooshie is the command list guru in these parts. I seem to recall him posting various ways do this. I would do an advanced search on his posts.
wvandyck
Post by wvandyck »
Most likely stating the obvious for many here, but this will be helpful if I forget how and do a future search :lol:
Searchable PDF
Open the Commands window, File menu>Prnt>PDF>Save PDF
https://www.dropbox.com/s/nbcyxfxcyty4s ... F.gif?dl=0
