What causes bounces to slow down?
Re: What causes bounces to slow down?
This is a good thread. Everyone should know the sudo purge trick.
I'm glad it's a short command and easy to remember.
If it's the last command you ran, hitting the up arrow will cause it to reappear after you open Terminal.
Those long terminal commands scare me like I'm gonna toast the whole system with one letter out of place.
Fortunately, Terminal supports Copy and Paste. Except for the shortest, I never remember and typing is a time waster, especially since a missed mark, space or incorrect capital can cause a command to fail. killall Finder is a good example—try it with a lower case 'f' and you will see that nothing happens.
I keep and update a .txt document called Terminal Commands OS X with an alias to it on my desktop. In it, I also include directions for dealing with ACL Not Found, emergency boot and many arcane system commands that have become useful over the years.
To me, these are the essentials:
Memory purge: sudo purge
Re-launch Finder: killall Finder This is way cool. It relaunches the Finder in a few seconds without the time or issues caused by Force Quit. Allows certain tasks to take effect without rebooting and does not interrupt a Time Machine backup.
Enable Trim: sudo trimforce enable OS 10.10.4 and later if booting from a non-Apple SSD
Repair Permissions (OS 10.11 and Later): sudo /usr/libexec/repair_packages --repair --standard-pkgs --volume /
Show Hidden Files: defaults write com.apple.finder AppleShowAllFiles TRUE
killall Finder
Re-hide hidden files: defaults write com.apple.finder AppleShowAllFiles FALSE
killall Finder
sudo commands require your admin password every 5 minutes.
This last post should be either a sticky or in the TIPS sheet. Very helpful, Mr. H!
daniel.sneed
Post by daniel.sneed »
Great post, Mike!
I'm gonna copy - paste.
Kurt Cowling
Post by Kurt Cowling »
I believe that the current buffer size will also affect time to bounce. Smaller buffer settings take longer to bounce in my experience.
DP 11.34 , 2021 MacBook Pro M1-Max, 2017 iMac Retina 5K 27-inch, Omnisphere, Trilian, Stylus RMX, EZ Drummer 2, Falcon, Real Guitar, Sample Modeling brass. Audio Modeling reeds, strings, Kontakt 6, Flux Pure Limiter 3, PSP Vintage Warmer, PSP MixPack, PSP StereoPack, PSP Impressor, Altiverb 7, Izotope RX10 Standard, Yamaha S-90ES, Yamaha MOXF-8, Yamaha MX60, Sibelius subscription, Adobe CC and Motion 5.
MIDI Life Crisis wrote:This last post should be either a sticky or in the TIPS sheet. Very helpful, Mr. H!
I totally agree. Let's at least put it in the Tips Sheet. Mike? You want to just copy your post over to the Tips Sheet Thread?
Shoosh
I'll clean it up a little and do so.
frankf
Post by frankf »
Is there a difference between using the killall Finder terminal command and quitting Finder from the Finder, Activity Monitor, Force Quit menu?
Frank Ferrucci
http://www.ferruccimusic.com
I was under the impression that OSX's memory management got a lot more inscrutable and opaque somewhere around Mavericks when Apple introduced "Memory Pressure".
https://support.apple.com/kb/PH19644?locale=en_US
mikehalloran wrote:I'll clean it up a little and do so.
Thanks for doing that.
Shoosh
philbrown
Post by philbrown »
Kurt Cowling wrote:I believe that the current buffer size will also affect time to bounce. Smaller buffer settings take longer to bounce in my experience.
Hadn't thought of that factor.
Definitely worth testing out. Thanks a bunch Kurt.
Maxxy
Post by Maxxy »
Yes thanks for that Mike
You have shown me the way here over time ...... with the repair permissions and many other insightful posts ....that's a great memo file you have given us....thank you
It may be useful to know about 2 small apps I got somewhere along the way....one is 'Memory Clean' which may do the purge memory task... I'm not sure exactly but it has a nice interface and shows you any large RAM using open apps ...and indicates your available RAM in the menu bar
I am also quite nervous with Terminal stuff
Also 'Invisible' will open and close invisible files with a click...both apps can sit up in the Menu bar at the top of the Mac
I think I may have heard about these apps here at this great forum!! I've learned so much
Thank you to all
